Kick panel Speaker Mounts
K5 Blazer
Sant Cruz, CA
Holden
K5 Blazer
6.0L LS
Installed a pair of kick panel speakers and they sound like crap. I don't think it's the speakers, I think it's the panels and the tiny space for the speakers. I sound deadened the sheetmetal behind the panels. Thinking about taking the panels off and sound deadening the plastic panels. Cannot run any bass thru the kick panel speakers or else the plastic panel vibrates and the speakers sound like junk. I regret spending nearly $200 for these panels. Seeing if anyone has had any luck making them sound decent or any ideas on how to do that?
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Can try "bolting" the speakers to the panels instead of screws. Maybe some sealer under the flange.
Shouldn't be running bass through components anyways. That's what subs are for. Kicker isn't terrible but isn't high quality anymore.
956moe
Moses
Gmc Sierra
:oops: oof i got some cheap plastic ones from ebay.... still haven't had a chance to install them. But for sure they will need sound deadning.
mxer147
Colorado
Jack
k20
They look much higher quality than the $35 I spent for some $2 cheap plastic covers which I plan to reshape, reinforce and paint. I don’t expect much from them other than mid range and not cutting up my doors. Speaker functionality is highly dependent on head unit and matching speakers with head unit impedance. An amp will also boost the performance significantly but will also increase $$. Impossible to have a low $$ symphony. I would glue a thin layer of hard material (HDF) to the backside rather than sound deadening.
K5 Blazer
Sant Cruz, CA
Holden
K5 Blazer
6.0L LS
My stereo does have an amp and I will install a sub but there is some bass that comes thru the speakers as well. These speakers were not that expensive but the system should sound better than it does. Not sure if high end speakers would sound better.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
Typically the enclosure is what makes a speaker.
83Stepper
Massachusetts
Chad
Speaker quality does have an impact on audio quality, just sayin...
Do you have other speakers wired in for your fronts as well as the kick panels or just those? Also be sure to check the positive and negatives are wired correctly, you'd be shocked how many people do this thinking one side was hot when it was actually ground. I've got some cheap Pyramids in the dash and Scosche 6x9's in the rear of my 83 right now and it actually sounds pretty darned good. Adjusting levels of treble and bass as well as fader will help. If you want to get fancy you can add in some caps to cut out lows on the mids to aid in sound quality.
thefoxtango
