- May 18, 2020
- Auburn, Washington
- Todd
- K20, C10
Good points.The biggest issue you’ll find with older Duramax trucks or any older electronic injected diesel for that matter, is that many have been abused by kids who threw a tuner on dad/granpa’s already well-used old farm truck and ran the piss out of it with little to no maintenance.
Look at what you’re buying carefully if you go the diesel route, many of the drivetrain components are far more expensive than that of a gas truck and a “cheap truck” can turn expensive really quickly if you get one that’s bad enough.
But from the flywheel back it’s apples to apples.
Not advocating diesel per se based on @Frankenchevy needs. And historically there is a pro-gasser sentiment from many in this forum, but even the mighty 8.1, new 6.6 GM gasser or 6.4 hemi or Godzilla motor will get absolutely walked by any new diesel or in this case an LB7/LLY/LBZ with a $300 tow tune. Add in altitude and slowing that load coming downhill and altitude will widen the gap made by the diesels skinny pedal. And an exhaust brake can be added for the other half of the arse whoopin.
