Looking to buy our first 6.2
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Looked at this one today. Two years ago the 17 year old who was driving decided on a 383 swap. I was told that he’d only made it as far as removing the radiator and there were no batteries. I went down with a couple batteries, rad hoses, some coolant, fuel and tools.
Unfortunately he’d cut the trans lines, engine oil cooler lines, radiator hoses, there was a hole in the radiator, missing battery tray, and the interior was a mess. Other thing I was worried about is that the oil had been drained and the drain plug was left out for two years.
All stuff we’d work with, but they wouldn’t budge on the price. They were asking $5k, we offered $4k because we were unable to hear it run due to the oil cooler lines issue and no parts to loop it. They were quite a ways out of town with no parts stores around. Unfortunately, this was a 10 hour round trip to go look at it. I’d like to know it’s a runner and the transmission works prior to making an offer.
Btw @bucket , it was a 700r4 and the spid showed it as original equipment. Early 700 operated by a 17 year old had me a bit concerned too.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
We may expand our search to gas suburbans. A SBC with an OD 4 spd will be easier to find. Gas mileage will be 25-30% worse, but I’m not sure makes up for the things that scare me about a 6.2 either.
Who knows…It seems that people aren’t very good about listings anymore. There always seems to be much more wrong with the vehicle than was conveyed. This will be a battle of numbers. I need to see everything within a 30 mile radius. I don’t think we’ll go very far out of our way to look from here on out.
ByrdDog
Amarillo TX
Robbie
Chevy
Gas will be much easier to get parts for. I searched around for months trying to find replacement heads for my 6.2 before stumbling across a machine shop that would rebuild the old ones. I was really close to pulling the 6.2 & dropping in a 383 crate motor.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Most (if not all?) 3/4 ton Suburbans have 56" rear springs. How many leaves are in your m1008 packs? Iirc, my set has 9 and I'm going to use them as-is in my Suburban. My other Suburban has 8-leaf packs from an '83 C30 and they ride pretty similar to the 5-leaf 52's that were originally installed in that Suburban.
Imho, a 255/85/16 tire is a great match for stock ride height and stock type, narrow wheels. Although it is a fairly uncommon size. Otherwise, a 285/75 is a good size too, despite many people thinking they are "too wide" for a 6.5" wide wheel.
10 leaves total, for what it’s worth. Eight in the main bundle and and overload top and bottom.
Those should ride just fine under a Suburban. I should have stated, mine from an '83 are 8 leaves, plus the bottom overload leaf. I don't have a top overload spring. The Suburban rides pretty well.
Also, I did realize that my shortbed 77's rear 56's have 9 leaves, plus the bottom overload leaf. It doesn't ride too bad either. Not as good as the Burb, but it's a short wheelbase pickup.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
I figure I can remove leaves, if need be. Either way, no way I should be under-sprung.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
We got it
idahovette
Weiser Idaho
Perry
K20-K10
Looks like they washed it for you!!!!!!!;) It's clean
MrMarty51
Eastern Montana
Martin
Is Your new BURB a gas enjun ?
I do have a FFM UNIT from my 2000 K3500 6.5 that I would give to Yoi if your new burb is a diesel.
It even comes with a new from Leroy Diesel seal kit.
And Leroy also sells the components to convert it to a feed the beast mod.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
We tried finding a decent diesel burb. We ended up with this 88 that’s a tbi 350.
We really appreciate the kind offer though!
Spork
