Weird solenoid looking thing
BryanS
Ft Pierce FL
Bryan
Blazer K5
Hello everyone
Anyone know what this is?
It’s on the firewall and I don’t like it :)
legopnuematic
Licensed Junk Dealer
MO
Spencer
Tip in switch for the factory ESC system
BryanS
Ft Pierce FL
Bryan
Blazer K5
I’ll look it up but what is an esc system and why would someone want it?
Electronic spark control. It fights detonation. If your distributor has a 4 wire plug,that goes through the firewall you have ESC lots of people have removed it over time. I like it others like it,some don't,I think most of the people that don't like it,theirs wasn't working right when they got the truck. If it senses detonation it retards timing 4 degrees,if it still senses knock it pulls another 4 degrees until the detonation goes away.
BryanS
Ft Pierce FL
Bryan
Blazer K5
I found it. Thank you guys. Can find it in my next post “free crap to anyone looking for old emissions epquiment” along with this spooky looking octopus I found. It is literally hooked up to nothing
BryanS
Ft Pierce FL
Bryan
Blazer K5
Electronic spark control. It fights detonation. If your distributor has a 4 wire plug,that goes through the firewall you have ESC lots of people have removed it over time. I like it others like it,some don't,I think most of the people that don't like it,there's wasn't working right when they got the truck. If it senses detonation it retards timingb4 degrees,if it still senses knock it pulls another 4 degrees until the detonation goes away.
Since it is not the original engine ( early 90s 454 I think) I’m assuming it’s not the original distributor. It does not even have a vacuum hose hooked up. I like the idea of the esc but don’t think it’s in the cards
Yep the esc would have gone with the original engine and distributor I'll take all the esc stuff if you want to pull it. The controller is behind the glove box. As for the octopus thing. You may want to keep it and hook it up correctly. Or at least see what the P.O. did as a work around for not using it. It vents the gas tank,but more than just venting,heck it would vent with no gas cap, but venting open it can pull in moisture to the fuel tank (water in the gas) and also can vent gas fumes into your garage. That octopus vents the gas tank in a controlled manner. Anyways P.O. had to do something to vent the gas tank, or as it pulls fuel and can't pull air into the tank it will starve for fuel. Like when you put your finger over the end of a straw and pull the straw out of the cup the coke stays in the straw. Same deal the fuel can't move if air can't get in. P S. It's not enough vapor to start a fire just enough to make your garage smell like gasoline.
BryanS
Ft Pierce FL
Bryan
Blazer K5
I like the smell of gasoline:)
I’m assuming the fuel vent line is cut somewhere.
I need to figure out what PO did with the gas tank too. The fuel gauge does not work and there is a holly pump on the frame that taps into the original fuel line and sends a rubber hose up to the engine. Havent seen the vent line to the tank but assuming it’s there somewhere
My octopus had a bunch of lines maybe I yank all of them and just run a new vent line to it to minimize moisture into the tank?
It's not complicated to get it hooked backup and functional. Give us a couple of good pics so we can see all the hoses,and post year,make and original engine configuration so we can determine where everything went to begin with. If you have an open vent line somewhere,for now put a clear plastic fuel filter on the open end. It will keep dirt and bugs out of the vent line/tank until we vent it correctly but also will still allow air in.
EvilGenius
Metro Detroit
Darien
Yeah the factory charcoal canister is pretty slick. There is a thread on here on what each connection is for here.
The short of it is the vent line from the fuel tank runs to one of the ports on it. One of the ports runs to the same line as PCV vacuum. Another runs to I believe ported vacuum. When engine is off the charcoal cannister is unvented. Fumes from the tank slightly pressurize the system as the fuel evaporates. No smell because of this. There may be a build in relief valve for scenarios where the pressure gets too high. But when the engine is running the stored fumes are "purged" from the cannister into the engine intake via the same hose as the PCV. That third vacuum line is the purge. It uses a vacuum signal from the carb to open up the valve leading to the intake.
Simple to set up with some vacuum lines and simple to understand with some reading of that thread. And smell free. The biggest hassle is some of the vacuum line sizes are different. Makes the truck much more livable.
David King
Crestview Fl. 32539
C-10
Can the fuel vapor canister be disassembled to replace the filters? I have same canister as shown in BryanS post.
59840Surfer
Montana
Joe
There is an ECS Canister Filter listed --- year is important, but for the most part, they have some listed as (and there's a lot of crossover in various models for the same part):
Standard Motor Products (SMP) Vapor Canister Filter fits Chevy K30 1977-1986 61KGJY
Just pull it out and push the new one in. There should be a little plastic bar on the bottom of the can that holds it in place.
Gads --- I haven't changed one of them in a service for maybe ---> 20 years or so!
BryanS
Ft Pierce FL
Bryan
Blazer K5
Ricko if you help me figure out were the esc is and exactly what wires connectors go with it I’d be happy to send it to you.
I should be working on the truck this weekend
Some vapor canisters are much simpler than the one in the picture. My ‘75 has one hose to the gas tank vent and one hose that used to go to a dedicated vapor port on the Quadrajet. The carburetor port apparently only vented under certain throttle conditions.
I now have mine vented to atmosphere (added a brass fitting on the air cleaner body) because I have a newer Quadrajet. For a while I also tried using a T in the PCV line, but it seemed to lean out the idle a little too much.
zacharyb
