Overheating 87 TBI
rys272
saskatchewan
rylan
wrangler / sierra classic
How hot does it actually get? Put a real gauge on it, and see what happens. You may be pleasantly surprised.
When does it overheat? Idle? Going down the road?
Are all the factory rubber baffles/gaskets/seals around the radiator in place? Any air that goes around the radiator instead of through it is wasted airflow. People toss those thinking they aren’t important, GM wouldn’t have put them there if they weren’t needed.
Does the truck run as expected? How is the tune?
Gets hot to the point where it shoots out of my radcap all over my driveway? overheats no matter what idle, in gear, going slow, going fast.
Haven’t been able to get her up to temp and really test her today after drilling two 1/16th holes because I’ve also been working on this misfiring issue but do believe that has done the trick will post again if it starts overheating again, probably going to change fan clutch regardless of this working.
rys272
saskatchewan
rylan
Seems the bypass is plugged or something along the lines. Got a new thermostat drilled two 1/16th holes and works awesome doesn’t overheat doesn’t quite get up to temp as I’d like but a lot better than before and it’s still pretty cold here so imagine won’t be a problem in the summer if not I’ll just buy a new one and go with 1 1/16th hole. Still going to replace that fan clutch and pull freeze plugs etc.
edgephoto
Stafford, CT
Greg
GMC V3500
7.4L
You should give your system a nice flush. Get some Citric Acid powder. Mix 1lb to 5 qts of warm water. I would mix up 2lbs worth.
1. Drain cooling system
2 Remove thermostat
3. Fill cooling system with the citric acid mixture
4. run engine for at least 15mins. 1 hour is best.
5. drain the cooling system
6. using a flush tee in the heater hose flush with clean water until water is coming out clean
7. install thermostat
8. fill with proper mix of coolant
Either buy a thermostat with a jiggle pin or drill a 1/16"-1/8" hole. This will help get the air out. Also using a vacuum filler really works well.
Mercedes and VW sell citric acid over the parts counters as a cooling system cleaner.
Many people plug the bypass on purpose,some water pumps aren't drilled for a bypass. If you buy one of those waterpumps they tell you to run a drilled thermostat. I wouldn't mess with the fan clutch unless you are still having overheating problems,run the drilled Tstat awhile that maybe all you needed.
59840Surfer
Montana
Joe
Absolutely stumped on this I’ve replaced almost everything and she still slowly overheats honestly lost for words
Took heat gun to it & is accurate enough to gauge
Fan shroud is good
Stuck glove over rad cap hole didn’t blow up the glove
Have tried 50/50 & 70/30 coolant
New rad
New water pump
New coolant temp sensor
New rad cap
New overflow tank thought possibly cause there was a crack in it it could mess up the pressure
Have tried 3 195f thermostats and have tested them every time before putting them in, 1 thermostat I drilled two 1/8 holes in because I thought there could be a possibility it was airlocked, this fixed the overheating issue but engine wouldn’t get up to temp even after 2 hours of driving
Last things I can think of is head gaskets (highly doubt), fan clutch seemed fine when I replaced water pump, maybe when I put new rad in I installed hoses differently???, water pump isn’t reversed
Should mention it’s always overheated since I got her but the rad was in ROUGH shape so that’s where this rabbit hole started
I just fixed another GM with the same problem.
The owner did everything just like you which makes it very hard to diagnose when they start installing parts like a monkey with its hair on fire and once everything is done, the problem still exists.
Go back to basics .... assuming the thermostat is working WNL ... the holes you drilled into it won't make much difference.
Here are a few observations that are critical to a good diagnosis --->
1. If you get into an overheating condition at less than 20 MPH or idling in traffic, you should suspect the thermal fan clutch.
2. If you get a slow rise in temperature at speeds greater than 45 MPH, suspect the radiator for heavy restrictions, as the thermal fan can't move more air than driving at a speed higher than the fan can achieve.
3. Bubbles or air in a GM cooling system (the exception is a Pontiac Fiero) - cannot exist once the thermostat opens, at least partially.
♠There are no zones where air can collect - this assumes the heater coolant flow is intact and operating with a flow restriction in it - somewhere.
♦ Many - not most - GM heater circuits MUST have a flow restrictor in it to slow the flow through the heater core!
4. A 195°F thermostat is a very good idea; I use the same in all my GMs.
Try this to help with a deeper diagnosis ---
Take an old-used radiator cap --- and remove the lower-smaller diameter rubber seal.
♦ Rip it completely off.
♦ This has now become a tool for testing your cooling system.
Install this modified cap on the radiator itself, start the engine - getting it up to at least 1/2 of the thermostat temperature allowed.
Stop the engine and watch to see if the coolant is sucked from the reservoir, back into the radiator.
♦ This may take a few minutes to happen.
DO this start-up - get some heat - shut down --- a few more times, watching the reservoir so that it doesn't get too low.
♦ You must keep a sufficient amount of coolant in the reservoir at all times!
There may be SOME air bubbles at first, but it will cease after a short while.
FUN FACT: you can "help" to purge the air from the system by FIRMLY squeezing the upper hose and letting go to help pump any air out of the system.
WHAT WE EXPECT TO SEE: We need to get to where there is no more air in the system.
♦ The lower seal, missing from the old cap, is what will allow free travel between the radiator and the tank.
♦ Report back with your findings so we can decide on the next step.
You HAVE TO climb the limbs of the LOGIC TREE correctly and in sequence - to arrive at a good diagnosis, and we need to get the basics out of the way first. .
REMEMBER ---> OVERHEATING and RUNNING HOT are two different things.
Overheating means coolant is actually hitting the ground!
59840Surfer
Montana
Joe
Ya---Why?
Because they don't allow the system to hold a suspended vacuum after shutdown.
♦ This is important so the surge or overflow tank can supply coolant - in a solid stream of coolant with no air - back into the engine.
I have had boneheaded customers let me persuade them to take the Lever Vent caps off, sell them a non-lever-type cap, and later have them come back on the tow truck with the engine overheated ---
.... and the old Lever Cap back on it.
SquareRoot
Until you release the lever it's sealed. I don't get what you're saying. The surge tank is vented anyway. So, unless the owner let the tank get below minimum at cold, it can't pull in air. Been using a lever type for decades without issue?
59840Surfer
Montana
Joe
Yeah --- they are fine for a while.
Then they leak when the system is cooling, the liquid condenses and draws a vacuum in the system.
The LeverCap is a weak spot and every time one of them came into a radiator shop I knew very well, that the owner would come out from behind his desk, rip it off the car, and throw it across the street at the used tire shop.
I think the used tires guy was selling the old Lever caps for 50 cents. He had a lot of them.
NOW comes the big part ---> Lever Caps are not "drop-center" style like the OE as designed by GM for their cooling systems for as long as I remember --- well --- maybe the 6V cars weren't so --- but they don't count.
The drop center cap design is designed to not allow the system to pressurize until right around 160°F. Then the center valve would close and the system would start to pressurize.
This is a pressure-cycle protection for short hops where it is not necessary to pressurize the cooling system.
If you don't use the drop-center style cap, you are actually defeating the GM design that works much better than any other system in autos.
59840Surfer
Montana
Joe
I've written several articles about GM Drop-Center caps and I am not want to do it again unless there's some specific questions.
I'll do a Copy/Paste on one I wrote a few years ago ... instead ...
GMs all use a "drop center" cap in that the little small metal disc in the center of the cap freely "floats" and is NOT kept closed by any springs at all.
Other vehicles don't typically use that design --- mostly - and only - GMs do.
The reason why is to keep the thermal-pressure cycles to a low count to help the radiator live longer. Every time it doesn't get to full pressure is another cycle that it can handle, saving the owner the cost of a new radiator in short time.
Now --- to test the correct cap - and spot the wrong one ---->
1. Hold the cap up, above your eye level with the cap generally in the same attitude it would be in, if it were installed on the radiator.
IOW -- imagine you were in the radiator neck, looking UP at the little disc .....OK?
2. Touch the little disc and see if it is loose.
3. If it is loose --- it's the correct design.
4. If it is held to the rubber of the cap and doesn't "float" freely -- it is the wrong design.
FUN FACT --- The NAPA store here where I live kept on sending the GM style caps back as defective because of the loose center valve ... until I asked for one, specifically --- and they told me they sent them all back as bad --- that is.
LEVER CAPS do not provide this design and instead they are sealed until the lever is pulled open. The effect of a drop-center cap design is totally lost in the Lever Caps --- that's why they are contraindicated as a logical replacement for a GM radiator cap.
bryanedge117
