2 post shop lift
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
I've actually done this before. 1980 something Chevette in a drive under basement garage,doing an engine swap. David's stepdad was wedging 2x4s between the front bumper and the floor.I was like,what are you doing if this thing falls I'll be crushed and impaled by 2x4 fragments. I wasn't afraid of it falling, held up by chain hoist around basement beam. 2nd seperate log chain, safety chain around beam and front of car.
I grew up with chevettes because my dad always had one and ordering new a 1981 black chevette with the F41 ralley suspension (still in around lol). He used to change clutches with drive up ramps. He would set trans on his chest and change the clutch. Once he said he fell asleep underneath changing one out lol.
squaredeal91
Greg bush
1991 SB
Getting closer! I ordered a little extra but Didn't expect to have enough to make a nice ramp into it. Brush finish so I might not slip so easily lol
I'm surprised you went with a broom finish. Is this going to be an exterior floor?
Hey Mr Concrete, I've got an unrelated question for you. The shop side of my barn has a concrete floor that has some kind of rough-ish and slightly lumpy surface. Is there some type of surface grinder I could possibly rent somewhere to smooth it out a bit? It makes it a little annoying to push cars around on wheel dollies.
squaredeal91
Greg bush
1991 SB
Have this crane and seriously considering sticking it in the corner to use for pulling engines and other things. If it didn't bend near the middle it wouldn't work for me but measurement wise it will fit good in the corner and be at a useful reach. I could always shorten it too. It does all work however the rotation motor needs rebuilt or replaced. It struggles and leaks allot. Maybe it only needs resealed. Either way what do you all think of the idea?
83 Box
Louisianna
c10 Silverado
A friend who sells 2 post lifts, used an new, once told me the two most important things with a two post, other than weight capacity and equipment condition, is a cross member at the top of the towers and anchoring them in sufficient concrete with deep enough anchors.
Yeah they have floor grinders you can rent. They look like a floor buffer only with grinding stone blades under it.
If you know somebody with a walk behind power trowel they have these too:
78silverado
