rys272
- Jan 12, 2025
- saskatchewan
- rylan
- wrangler / sierra classic
Absolutely stumped on this I’ve replaced almost everything and she still slowly overheats honestly lost for words
Took heat gun to it & is accurate enough to gauge
Fan shroud is good
Stuck glove over rad cap hole didn’t blow up the glove
Have tried 50/50 & 70/30 coolant
New rad
New water pump
New coolant temp sensor
New rad cap
New overflow tank thought possibly cause there was a crack in it it could mess up the pressure
Have tried 3 195f thermostats and have tested them every time before putting them in, 1 thermostat I drilled two 1/8 holes in because I thought there could be a possibility it was airlocked, this fixed the overheating issue but engine wouldn’t get up to temp even after 2 hours of driving
Last things I can think of is head gaskets (highly doubt), fan clutch seemed fine when I replaced water pump, maybe when I put new rad in I installed hoses differently???, water pump isn’t reversed
Should mention it’s always overheated since I got her but the rad was in ROUGH shape so that’s where this rabbit hole started
Fan shroud is good
New rad
New water pump
New rad cap
