scenic760
- Jan 12, 2021
- SoCal
- Chris
- Suburban K10
Another day, another question!
I went to put the weather stripping seals on and nothing seems to be lining up 100%...
It's my fault as I made the mistake of having the body shop remove all the old rubber for paint and dropped of a new complete Precision kit to replace everything. I picked it up and things were 1/2 done, and the 1/2 that was looks like they put the new guy on it.
That being said, I'm not sure how the exterior window beltline is supposed to fit? The way it snapped in, the rounded side fit inside the door sheetmetal...which I can see might be correct as the window would push it against the door to seal it...AND it rides up the door felt channel to seal on the inside. However I could also see it fitting over the door sheetmetal to create the seal. I looked for an installation video but didn't find one.
Unfortunately I think this is only the beginning of my weatherstripping problems...
