Review: Simple, stand alone GPS tracker
Tonimus
Phoenix
Tony
C10 Suburban
The recent post about a stolen and chopped up truck, and the suggestion to add a tracker, made me want to post this.
For the last five years, I've been using a device from a company called MoniMoto. https://monimoto.com/ I started out with a model MM6 (old and out of production) and now have had a MM7 for several years. Nothing went wrong with my MM6. When the MM7 was released, I emailed the company and asked if I could do an upgrade, and they obliged.
The MM7 is a completely self contained "alarm" and GPS tracker. It's EXCELLENT for motorcycles or other small things easy to move, but also works great for cars. It uses a pre-paid cell service, also purchased from the company. The service is $50 a year. The current model is about the size of a deck of cards, is powered by 2 AA lithium user replaceable batteries, and comes with a passive fob. It has a built in accelerometer in addition to the GPS chip.
They also have a MM9 which is smaller and rechargeable, and a smaller, cheaper version for pedal bikes.
The way it works, is you hide it somewhere in the vehicle. If the passive fob is not nearby, and the vehicle moves or even shakes (users can change the sensitivity) like when you stand up a bike, the device sends you an alert via app and simultaneously calls your cellphone. If somehow the vehicle is taken when there's no service, you can log into the app and tell it the vehicle needs to be tracked. The next time the device wakes up to check it's status (you can also change the interval for this) and it see's the alert, it begins active tracking.
It has given me fantastic peace of mind with my motorcycle. I believe I'm going to get another for my 'burb.
Here's an Amazon link. I purchased mine at a local Cycle Gear. https://www.amazon.com/dp/B09Q69N4VT/
YakkoWarner
Central Texas
Wolf
R2500 Suburban
I suppose a well hidden Apple Airtag type device would work as well if the stolen vehicle moved through a populated enough area for the airtags to work/communicate. I don't have that kind of phone or working service where I live so it wouldn't help me, but there are lots of people who it would work for.
On my British cars I'd just take a key component from the engine compartment with me when I parked, at which point even if the would-be theives had the keys they wouldn't be going anywhere (and obscure British parts aren't something someone would likely have handy or be able to go buy one of quickly even if they knew it was missing).
Tonimus
Phoenix
Tony
C10 Suburban
The downside of an airtag is if the thief has an iphone, they'll get a notification after a bit that there's an airtag following them.
Scott91370
Burleson, Tx
Scott
Sierra1500
This is true but if you hide it good enough they will hopefully just ditch the truck in a busy parking lot.
JoeyPepperoni
