Exhaust collectors for manifolds
Slooptin
Denver
Vance
k30
Going back to manifolds on my sbc as the shorty headers leak constantly and make messing with plugs impossible. Anyone know where to find collectors and flanges that fit the stock manifolds with the donut gaskets? I’m looking to fab up a 2 into 1 exhaust so I have everything else (pipe, y pipe, muffler, etc.) but all of the collectors I’m finding are the flat style ones for headers.
legopnuematic
Licensed Junk Dealer
MO
Spencer
legopnuematic
MO
Spencer
To what I had removed from my 76 and 79, yes. Only difference is those have that ‘pilot’ to hold that donut gasket in place, the ones I had removed from my trucks were just bell mouthed, no pilot.
So visually they seem to match, got a picture of the manifolds you intend on using?
This is what came off of my 76
legopnuematic
MO
Spencer
And if the ones linked above are incorrect for your application, looks like that same seller offers many variations and types of downpipe stubs.
Slooptin
Denver
Vance
k30
Those manifolds are basically what I’m going with except mine will have an o2 sensor port on the driver’s side (tbi engine). Those bellmouths were what I was looking for but the eBay ones with the pilots above might be better I’m thinking
Slooptin
Denver
Vance
k30
These are what I’m ordering
ali_c20
Austria
Alexander
C20, K5
I cut off the material below flange on the manifolds of my K5 to have a flat sealing surface. I used a fat flange with a flat gasket. Works great, no leaks.
SquareRoot
You should seriously consider some Hookers at this point ;) 10X better than the OEM style. Better in every way.
Slooptin
Denver
Vance
k30
You should seriously consider some Hookers this point ;) 10X better than the OEM style. Better in every way.
I considered them but they're over 2x the price of stock manifolds and this truck rarely sees anything over 3k rpm
legopnuematic
MO
Spencer
Good exhaust makes power down low too.
Very good point.
My 76 has been open headers a couple times, most recently was when I fitted the “new” headers and before I started on making the side pipes. Just moving it around the shop it had no low end at all, pathetic really.
Scavenging is real kids, it makes big difference, not only in the power and torque, but helping draw the next fuel/air charge in while evacuating the chamber of spent gases (tunability).
If you look at real race headers the collectors are much longer than most street headers are. So if anyone wants to run open headers with normal headers, add 12-18” of pipe to the collectors and it’ll be more betters.
ali_c20
Austria
Alexander
C20, K5
I have the hookers on my C20...great quality and they fit like a glove. Nice casting, nice machining, all straight and they come with flanges and hardware.
Matt Lutz
Bastrop
Lutz
250 4.1L
Broken85
Cumberland, NJ
A
I think I now have tetanus
thatgermanguy
