700r4 & Edelbrock TV Bracket
PartsMan79
Enid Oklahoma
Josh
c1500
Yes I have searched but cannot find my actual situation.
My 1983 GMC c1500 has the original 305 and 700r4,
but a prior owner installed an Edelbrock 600 on an adapter and it wants to shift earlier than I would like.
Searching the internet I see some cheaper ($15-50) corrector kits that only have an adapter for the carburetor arm,
or more expensive ($120-150)kits that have a new bracket that attaches to the manifold also.
Has anyone on here been in my situation and know what I need to adjust it right?
Attached pic of my current set up.
geolee
illinois
george
I bought a holley bracket and modified it. Just hold button and open throttle all the way is how I set mine
Don't skimp or cut corners on TV it's the fastest way to an early death on a 700r4. . Cost for a pressure gauge and a proper correction bracket IDK 100.00. Price of R&R + rebuild 700r4 what $2500.00
SirRobyn0
I made my bracket from a combination of an oem manifold bracket and a cheapie aftermarket bracket. I just cut them and welded them together in in order to get the proper geometry for the cable with the edelbrock carburetor.
1STLS1
West Phoenix AZ
MIchael
This
This. What is the proper correction bracket?
If the arm is the wrong length or angle line pressure will be wrong. Very hard on a 700r4 it's not like a th350. The cable controls pressure,not downshifts.
Go to bow tie overdrives 2nd link in my screenshot, download the pdf read it and study it, hopefully it explains things in a way that you will be able to set your car up correctly.
the bracket, as long as your engine was originally 4 barrel, is fine, but if your truck was a 2 barrel(305...? no qjet in sight... smells like it was a 2 barrel to me )the bracket isnt in the correct spot.
scrap--metal
MN
Calvin
'85, '81
K10, K20
@PartsMan79 do like Ricko says and research the setup instructions on bowtie overdrives website. I'm using their TV Made Ez system to control the 200-4R under an Edlebrock carb in my Camaro. It's well worth the price if your not confident in the system you currently have. I had nothing for that car since I replaced a TH350. I'm not affiliated, but I've been enjoying the overdrive trans they sold me for almost 20 years.
also late th350 uses a tv cable thats actually a kickdown cable.
ANNOYING.
PartsMan79
Enid Oklahoma
Josh
c1500
Sorry for the lack of updates. Life, weather, and a wrong cable have slowed this project down.
I found the real problem. My TV cable was damaged in a small fire I had last year and cannot be adjusted.
I now have the right cable stabbed in the transmission and a adjustable bracket waiting to be put on.
Scott91370
Burleson, Tx
Scott
Sierra1500
Can't wait for the update (and pics!). I do not have one of these on mine but the shifting happens at the right times/RPM but I've always been a little worried about its lifespan.
You are living a very dangerous life. TV is the most important thing on a 700 r4
erikm00
