- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
Hmm, good info.
I'm thinking the front strap bolt may need cut by a 1/2" after I put on the tank. I will NOT be able to get to it once I put it up, and that will help tremendously.
I also caused some of my own problems with the trans jack.
FYI, I got to front strap bolt with long 18mm ratchet wrench, and just used wd40. Little at a time and determination. PB ran outta air, lol.
Passenger side will be different since both are accessible ( God willing ).
Yes, simple inexperience makes for turtle time.
do you mean too long to get a socket on it ? And as long as you have threads with it cut down you should be good, just thread nut on , cut it, then thread off, slip in, then thread on
