Have you checked your ground?
Jeez, our newly painted bolts & studs has me concerned now. Thought about that when I did it.
Firewall ground strap to engine, two wires that ground at ECM stud; negative cable from battery to alternator bracket. Those got painted but battery to Frame left alone, and seems like a couple to front assembly where head lights and radiator are.
if they were clean when painted they should be fine but to be clear, your ECM ground is not linked to another ground right
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Oh no, I meant near the ESC module. Up top. I got my acronyms mixed up.
I didn't add anything.
zulander
Indiana
Edward
c30
I worked with a retired steel mill electrician, ground is the first thing he looks at, I learned quick, first thing I check, is it clean, and tight?
bubbalicious24
