Magnetic Block Heaters, Gas Engine?
gill finn
Massachusetts
Graham
Hello all, since we've entered the winter chill arena, the old 350 in my '84 c20 is a bit cranky in the colder weather. I can give it a tiny shot of starter ether and she cranks right up, but I'm wondering if anyone's yet tried one of these aftermarket magnetic block heaters? I've seen some videos of guys using them on older tractors without them, just sticking it to the side of the oil pan and I'd imagine the oil would contain a good core heat value once it heats up. Anyway, just wondering if someone's had some experience or am I just wasting $. Thanks a lot for any help and happy belated new year!
g
Now think about this. If you put a magnetic heater on the oil pan you will have 5 quarts if warm oil in the bottom of the pan. The block above it and the intake manifold,radiator,everything is still stone cold and trying to be warmed by 5 quarts of warm oil. If you use a freeze plug heater,radiator hose heater etc. Your heater core will be warm,the block will be warm,the radiator will be warm,lots more bang for your buck warming the 4 gallons of coolant. Warm coolant that sounds strange doesn't it.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
A $30 block heater has never done me wrong. Never replaced one either. Starts obviously way easier, gets heat in it wayyy faster. -20F last night windchill was about -50F. We've had a cold snap for a few days here lol.
I do run a small chunk of cardboard on the rad below single digits though. Usually get lazy and don't take it off until +30's, the truck doesn't care, it maintains temp just fine. Ive done it on new trucks too. Helps with warmup and keeping temp up, especially with winds and higher speed driving. White trash grille winter cover lol, at least it's not ugly and expensive as hell :anitoof:
77 K20
Montana
K20 5" lift
HT383 fuel injected
On my first K5 Blazer it came with a soft plug engine block heater. It blew out on the highway and I lost all my coolant in about a minute. Haven't run one since.
I have had several oil pan heaters of the magnetic type. Just stick them on the bottom of the oil pan and plug it in before I go to bed. Warm oil pumps a lot easier than cold oil and also heat rises.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
It wasn't installed properly. I've never had a problem. And I've torn down so many engines with those things and they were basically like removing the regular soft plugs lol.
Auburn, Washington
Coolant heater = better than oil pan heater. Warms everything but the oil. Oil pan heater leaves everything cold except the oil.
In the Arctic when it was not too cold yet, we only ran coolant heaters. One it got to be winter, everything got plugged into a quad plex electrical box under the hood. Coolant/block heater, oil pan, trans pan and battery maintainer.
v3500bigred
Washington State
V3500
Hello g
I recommend both together. I have used both a tank heater and a magnetic spot heater on the oil pan at the same time for 7 years when I live in Alaska on a 1978 Land Cruiser. I would plug them in 30 min to an hour before starting to thaw. I wouldn't recommend using them to keep them warm all night.
When I bought my trusty old '55 tractor, I had stuck a magnetic heater to the oil pan for the colder months. It didn't seem to make a difference, it starts up in the dead of winter without it.
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
Do not know how cold it gets in Mass, but Rick is right. Mag heaters work somewhat, easy to install. Hose heaters work great if it circulates. Easy to install. Block heaters, in my experience work the best. On my 6.2 diesel, significant difference in starting with/ without the heater. It is a small U shaped heating element, that slips into a soft plug location, mine on the front drivers side and is accessible without removing anything. Coolant will have to be drained. Clean block with sand paper, alcohol, and use permatex # 1 on freeze plug, wait a minute and install.
what tractor did you buy?
ck10sqbdy
