JamesSam
- Feb 15, 2023
- VA
- Sam
- Silverado V10
- 5.7 L 350 v8
I finally decided I would try a few more things before handing the truck off to the garage, and I would have to tow it in anyway. Picked up new: IAC valve, O2 sensor, and ignition coil. Just to see if anything would happen differently I put the IAC valve in. (Keep in mind I just recently replaced the TPS.) Started the truck and it was idling high and I was kind of expecting that. I let it warm up a few minutes then mashed the gas a few times and there is no stuttering in park which is an improvement. So it seems to be getting good balance of air and gas/ not bogging. Now I guess I need to do the paper clip tune up trick. If I can dial in a good idle I will definitely be replacing the Ignition coil l, unless the current one is looking great ( haven't checked yet), and the O2 sensor. I realized I forgot to look for an ignition module while at the parts place. Oh, I found the IACV, O2 sensor, and ignition coil all in one spot, the Advance around the corner from my house.
Let me know what y'all think. Feedback.
