Fuel gauge to tachometer, clock to fuel gauge
84_c10_GMC
Alex
hello,
Has anyone used the summit retro gauges to replace their square body gauges? I am looking at replacing my large fuel gauge with the tachometer and the small clock with a small fuel gauge. They appear to mount the same on both, just curious how they look after installed. Will be going in a 84 high sierra c10
Thanks
Alex
ChuckN
Bellinham, WA
Chad
hello,
Thanks
Alex
Hey Alex, when I did that conversion I used the LMC tach kit.
I could be wrong, and I don’t know if Summit includes any provisions for just swapping in a tachometer, but I think it generally requires a new printed circuit, and also the green plastic backing plate that has a space for the tachometer plug to sneak through the back to actually get to the tachometer. Apologies for the poor photo, but the LMC kit is pretty seamless and includes everything you need. Although, it will come with the stock tachometer that goes to 5k RPM.
84_c10_GMC
Alex
Thanks for the info. I was gonna go the route of pinning on the main gauge panel plug to get the wires to the new fuel gauge. And then run new wires for the tach. I found someone else post doing similar after I posted this. They used oem gauges off another truck. Although it appeared they didn’t have the clock like mine does. And just had to cut out the blank spot to fit the fuel gauge.
84_c10_GMC
Alex
In a different approach, anyone aware of a small matching tach that goes in an empty small gauge location I have?
I haven’t seen any small oem style. But I believe Holley/brothers had some that will fit in the oem guage holes.
84_c10_GMC
Alex
The summit tach is 3 wires off back of the guage. Ground power and signal wire. Other post on here used an inline fuse that plugged into your guage fuse panel and kept the original fuse also. And used the wire off the 2nd fuse to power the tach. Signal wire obviously goes to the distributor. So should not be to hard to get tach going. Main thing will be the wiring for the fuel guage from oem location to the clock location.
ChuckN
Bellinham, WA
Chad
You’re likely onto something there- I’m a little rusty since I did mine probably a couple years ago.
84_c10_GMC
Alex
Whenever I get around to doing it I will report back….. need to get the truck running and moving on its own at this point lol
cmichels83
Fargo
Glowshift sells a small one that will fit if you cut the whole for it. I replaced everything but the fuel gauge. Put the tach in the lower right spot because it was easiest to see while driving.
84_c10_GMC
Alex
LMC has gauges that will be a closer match.
Stock gauges
I’ll have to take a look but I didn’t think the summit gauges looked half bad for an oem style. LMC maybe cheaper though.
Camar068
10 yrs Air Force
ah...sorry about that, I didn't realize your initial pic had the gauges in it. They look nice.
And from the looks of it, the LMC tach will require a wiring harness making it more than Summit.
84_c10_GMC
Alex
Yea this tach is simple power ground signal. And just need to knock a hole in back of judge cluster box for them to go thru. Thanks though!
TDoc
Flagstaff, Arizona
Terrell
K10, K5
I just did something similar on my K5.
Truckandcarshop had the best price for ordering just the tach and fuel gauge even though they charge shipping. They also have an eBay store for some of their items and will send you a better offer if you add to cart or save in your watchlist. They don’t have a website like LMC you have to call in to order.
Truckandcarshop, LMC, summitracing all get the gauges from the same manufacturer.
I try to avoid LMC as much as possible, they have the highest prices and shipping rates.
keithself68
