1966 Ford Galaxie 500
custodian
Catawba
William
5.3 LS, 350
I KNOW, IT"S A FORD.
Original 352 4V, Cruise O Matic transmission, Power Steering. Has a Edelbrock 600 with 3”x14” reusable air filter. Has a cracked windshield. AM/FM/CD player with two six inch and two four inch speakers.
The following parts are NEW: Fuel sending unit (not installed), Starter, Cloyes timing gears and chain, 215/75/15 tires, PS and alternator belts, front and rear brake drums, front and rear brake shoes, all four wheel cylinders, front brake line hoses, rear brake line hose, front wheel studs and lug nuts, both exhaust donuts/seals, UPGRADED to a 67 Galaxie dual reservoir brake master cylinder, water pump, Champion aluminum radiator, upper and lower radiator hoses, aluminum heater core with heater hoses, valve cover gaskets, starter relay with positive and negative battery cables, coil, points and condenser, distributor vacuum advance, front sway bar end links, wiper blades. Seat covers.
Replaced the driver’s side mirror and added one on the passenger side.
Rust in the usual places, NO head liner (the wire cables are still there for the head liner).
$5500
74Blaze
Nashville, IN
Gerald
K5/Blazer
Not rich just used to hand-me-downs. That car was passed down from my oldest sister to my mom to one of my older brothers. He traded it in on a brand new 1982 Ford EXP.
fast 99
Spokane, Washington
First car I ever drove was a 1966 Galaxie 500. White two door red interior 351 V8 Cruise-o-matic Trans. It was the family "extra car".
probably a 352?
Another one of those never will happen would be a Coyote V8 conversion in a 1957 Ford Ranchwagon with a newer chassis. Basically a new car under an old body. Parents owned one when I was young. Am getting to old start a project that large now.
custodian
Catawba
William
5.3 LS, 350
Nope. Ford offered both the 351 and 352 among many engines for the 1966 Galaxie. Everything from straight 6 to a 428 (badged as a "7 Litre". The 352 was a Big Block (FE) engine. The 351 was a small block.
The 351 was introduced in 1969, so, no, there was not an option of a 351 in 1966. I've attached the engine codes offered for the 66 Galaxie.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
I want engine code R please
74Blaze
Nashville, IN
Gerald
K5/Blazer
Aw man, that means my memories from 45 years ago are not entirely accurate. It must have been a 289 car. Definitely wasn't a 352. And it was certainly a 2bbl car. Always had choke pull-off issues.
michaelk20
