1987 454 TBI stalls at idle after a short time
beady
Tidewater/Northern Neck VA
Mine
R20
Hello again, I have this new to me 1987 454 TBI suburban that I’ve been chasing problems down in. Today’s issue is stalling after a few mins of idling.
The previous problem was power being way down, to the point where it would max out at 47 mph and you could only use literally the first 1/4” of throttle travel before it would rev seemingly ok, but make even less power. This turned out to be a loose/worn distributor/cap. I replaced distributor and more, and it ran pretty well for a week. I put maybe 50 miles on it, but last week I started it and walked away and it stalled a minute or so later. Now seems to be the truck’s MO. What I’ve replaced or checked:
Brand new:
DUI distributor, coil, wires
Delco plugs
MAP sensor
Delco injectors
Delco FPR rebuild kit
Fuel pressure was 13 psig after filter
Timing set at 4-5 dtbc with ignition wire disconnected
Here’s a video of it stalling I took earlier today:
The last thing I did was the distributor, coil, plugs, wires all at once. The idle sounds great, nice and smooth, no bounce or bauble. I’d love any thoughts or ideas on what to do/check next.
Thanks,
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Have you checked for any vacuum leaks ? How old is the map sensor.
beady
Mine
R20
MAP sensor is a couple months old, a couple hundred miles old, tops. I haven’t tried spraying starting fluid around intake to check for leaks yet. But it doesn’t have a high idle, and doesn’t hunt either.
Vbb199
Salisbury NC
Vince
If you had a means to scan the obd1 interface, you could check manifold pressure.... but since those all seem to be gone from the internet and me and handful of people are the only people to own them now, you can alternatively back probe your MAP's output wire for its 0-5 volt signal, if youre DMM savy... getting a manifold pressure reading is pretty helpful in diagnosis of the old beloved tbi systems....
These systems are simple.
They need a map reading for fueling, a coolant temp sensor reading for fuel flow offset, a TPS sensor for the obvious, and a o2 sensor to adjust fuel finally.
If you care to check the map pressure reading, i can give you some instructions.
If you want to check your TPS voltage, i can give you some instructions, but they both require a DMM.
The map might be good, but it could be doing it job, and reading manifold pressure problems... we wont know without a scan tool , or checking it with a DMM, or at least using a vacuum gauge on the tbi.
Whats the story with the TPS sensor? New? Old?
Coolant temp sensor ?
O2 sensor?
fast 99
Spokane, Washington
FYI, TBI primarily uses MAP for fuel trim. O2 sensor only effects trim after reaching operating temp and usually will not stay hot enough after idling a minute or so.
As stated above, data would help immensely with diagnostics.
Another item check for excessive AC voltage.
Would be helpful to know manifold vacuum reading. If low would cause MAP to dump fuel causing stall. Without more information it's all a guess, from a bad ground to leaking EGR.
beady
Mine
R20
O2 sensor?
Thanks for the detailed reply. I had a scanner that would give ALDL live data until about a week ago. My son borrowed it for his friend to use, and the kid’s car got broken into and the scanner stolen from his trunk : (
I’m handy with a DMM (love my fluke 179 that has a thermocouple for temp readings), and have repaired a couple audio amps in the past, so would welcome what reading I should be looking for at the various sensors.
I’ve only had the truck a few months, so don’t know the age of anything I didn’t mention I’ve replaced.
I’m at my gf’s farm and not sure if my vacuum gauge is here or at my house 80 miles away. I haven’t checked vacuum yet. I do have a mightyvac type hand pump here, might be able to rig something up to use that…..
Thanks,
Vbb199
Salisbury NC
Vince
Thanks,
Ok, so on the map sensor, you have 3 terminals at the plug.
5 volt reference (grey/term c), MAP signal (green/term b), and ground (black/term A)
First, with key on engine off, back probe the 5 volt reference, just make sure its showing 5v. It should be. The truck probably wouldnt run without it.
Check the signal wire, and it should also be 5v or so, maybe a little less. Which is 100-105kPa. Thats normal key-on, engine off reading.
With the probes still in the reference and ground, turn the truck on, and see what the reading is. It will be between 0-5v. if the trucks running right it will presumably be about 1.5-2.0v at idle.
Let us know what you find there.
On the TPS sensor, you also have 3 terminals.
Sensor ground (black/term A), TPS signal (blue/term B), and 5 volt reference (grey/term C )
The same thing goes here... with key on, engine off, you ought to see 5 volts on the reference.
And over on the signal wire, you should be seeing like, .6-1.0 volts with the engine off, key om
It all depends on sensor orientation.. and mfg, but the important part is that we see somewhere in that range with the throttle blades closed.
For chits and giggles, slowly open the throttle , and see if the TPS voltage rises in correlation with your movement...
Report back on what you find with those sensors to start.
beady
Mine
R20
Thanks for that. However, since I complained the truck has been running normally, go figure. I’ve done probably 8 dead cold to operating temp, back to dead cold, including sone errands and turning the engine on and off and it only had one bauble. That was one of the first drives when a dog ran into the road just after I had started accelerating from a stop sign. The truck acted like it wanted to stall 2-3 times and I had to baby the gas pedal. Other than that one time it was flawless. Go figure.
It does two things still tho, it takes 2-3 seconds of cranking when cold to start. When warm fires right away. And seems to stay at a higher idle for too long after starting cold, and the idle in general sounds too high to me (no tach, so can’t tell exact rpm, but definitely higher than my 350 TBI used to idle).
beady
Mine
R20
Well…. I went to check timing (it was about 20 degrees btdc) and I pulled the timing connector wire to check base timing and the engine immediately almost died and started surging. Now it struggles to stay running again, lol.
The timing with the wire disconnected is about 4 degrees btdc. (Which it should be, I just replaced the distributor and set the timing a few weeks ago). What’s weird is when I plug the connector back in, the timing stays at 4 btdc and does NOT go back to 20 btdc. If I turn the truck off the timing goes back to 20. The idle drops way down when you pull the connector.
I found some screenshots I took using my scanner before it got stolen. They range from maybe idle, cruise, and pretty heavy acceleration. Oh yeah, Speedo doesn’t work so that’s why it doesn’t show any speed.
This video is if it “idling” on its own. I’m not touching the gas.
Thoughts?
Bill USN-1
US
Bill
Here's my reply to you msg on binderplanet.com
____________________________________
Best to post in the injection forum then PM.
Reviewed the link, you have several issues going on.
Looks like you have the AZFT chip in the 1227747 ECM.
Should be on the paper label and the silver foil on the chip itself.
454/TH400
I would recommend going to aldlcable.com and picking up a new data cable.
12pin GM.
That will allow the use of a windows laptop for data logging.
Better than a scan tool.
Next, fix the O2 sensor.
It is not reading in any of the screen shots.
Either it's disconnected/bad wire or bad sensor.
It never goes into closed loop.
Fix speedo/VSS
This will cause stalling when coming to a stop.
TPS is low. .35v
Someone may have played with the min idle screw or the TPS.
Should be 0.2%/.55v KOEO.
Every time you open the timing bypass you set an error code 42.
You cannot just plug it back in and have timing work.
You should turn off engine, plug bypass together.
Disconnect batt to clear all error codes.
Restart engine.
This FAQ has the basic sensor readings.
There are tons of TS posts.
Top of the injection forum has the FAQs
Here's the one to start with.
In it, there are links to all topics by just scrolling down the list.
trouble shooting is near the bottom.
The parts required link has each sensor listed with specs.
YakkoWarner
Central Texas
Wolf
R2500 Suburban
O2 sensor?
This is so similar to my intermittant problem where the truck just shuts off randomly - it hadn't happend for a few months and then just Tuesday I was riding along and had total power loss (but ignition was still on/live because all gauges were still responding, alternator was still outputting 13+ volts, radio still on, etc). I was going fast enough that the tranmission stayed engaged - which still weirds me out because I didn't think automatics could do that - so I rolled the key back to "OFF" and back to "ON". Engine immediately refired and ran fine. When it happens at idle I can confirm there is no spark/injector pulse until key is switched off, and then works properly immediately when turned back on.
I have been trying for almost a year now to hunt down anything that can provide live ALDL data - I hear rumors of such devices existing but have yet to meet a single person who has ever actually seen/used one. I figure its either an internet rumor or for some reason they have all been pulled from circulation. Maybe they no longer exist because of legal/intellectual property complications (since it is a GM propriatary system)?
gmbellew
Kansas city
glen
suburban 1500
edgephoto
Stafford, CT
Greg
GMC V3500
7.4L
I bought the allocable.com usb cable. I could not get it to work. When my truck comes back from the rest shop I need to use it.
It is a Windows issue and I have not been able to get the software to see it even though windows sees it.
Auburn, Washington
^Both yalls problem could be a random short somewhere? IMO if a condition is random it’s less likely to be a bad component. Maybe talkin out my …. But my 2c anyway
cheezeburger79
