1979 K10
- Jun 8, 2021
- Flagstaff, Arizona
- Terrell
- K10, K5
I’m trying to swap my idiot lights to gauges in my 86 k5 Blazer. I tried moving the pins around The big connector but I can only get the volt gauge to work. I used a pin out on another post but some of my wire colors don’t match. Fuel, temp and oil are all pegged and gauge lights won’t illuminate so I must have a few pins in the wrong spot.
I unplugged the original oil pressure sensor and realized that affects the electric choke warming up. Aka high idle when engine is warm. I either need to find a splitter so I can run two oil pressure sensors or abandoned the factory idiot light sensor and just give the choke 12V key on.
