Hi Everyone!
FINALLY starting the first stage of reassembly, painting the frame. I'm tired of not finding someone to blast the frame, so I'm going to do it myself in the driveway.
Once I get it "clean" (no old flaking paint, it's not very rusty so I'm looking for a good surface for the paint/coating to stick) I will be putting it back in the garage and starting the process with a metal prep and paint/coating/topcoat as needed. This truck will get plenty of use, so I want to protect it as much as possible.
I've heard good about Eastwood products as well as POR15, so I'm looking to make a decision between the two. Thoughts?
Thanks again to all who reply, this forum has great posts and really enjoy reading about others' rides!
Take Care,
KS in KCK
If you’re going through the process of blasting it clean to bare steel, you don’t want rust reformer type coating, you want paint.
Clean bare steel should get an etching or epoxy primer or any flavor of direct to metal or direct to rust type paint.
Any surface that gets blasted decently and primed/painted or at a minimum well coated with a dtm/dtr type paint over surface corrosion (not flaking) will be as protected as it can be.
Do some tests, but you’ll find that most all paint will bond well to decently cleaned surface rust as well. And rust that is sealed from oxygen will not continue to rust.
The devil is in the details though. Getting 100% clean and 100% coverage is almost impossible on something like an assembled frame. And it’s the 1% of crevices and mating surfaces between pieces of around rivets or bolts/holes that DONT get completely sealed that start the rust creeping again.
Not a huge issue if not left outdoors in the rain/humidity for years or if chlorides aren’t involved. (Road salt).
To counteract those conditions that’s where the oil/wool wax type penetrating coatings come in. They creep into those little spots that can’t be reached and provide a level of surface protection but they’re sacrificial and require periodic reapplication.
Bottom line is plenty of use is fine. Wet isn’t even too bad. But salt kills.
Keep the salt away and you’re good. Remember that frame lasted 40-50 years already with arguably less care than a fresh sand blast and paint. You’re not gonna make magic happen but it’s not gonna rust away for a long time.
Case in point. Buddy is restoring another old truck he’s had since a kid. 30 years ago he wire wheeled and painted the chassis and jambed it out for paint. In those 30 years it sat outdoors in seattle for about 20 years. Frame looks cherry and could eat off it after removing the dust and dirt. Little bit of rust poking out around from the nooks and crannies is all.
Or different scenario, daily driver, when we lived in the Rockies. Some chloride exposure in the winters. Every couple years, spray the chassis down to get as much dirt off as possible and spray bomb it with a couple cans of black paint. Did a pretty good job at keeping the rust away.
Part of the reason it’s generally easier to keep the rust away on a truck vs a low to the ground car and unit body construction. Less nooks and crannies hiding.
But in your scenario, unless “plenty of use” is gonna involve involuntarily turning it into a rolling salt lick in the winters, you have nothing to worry about until your kids are at least your age now if you just cannot up and paint it.
