GMC-IH
dragstews
Belleview Florida US of A
Jesse
Body 1954, frame 1975
R-100
406 ci SBC
You'll know I'm all about loading this old truck down with creature comfort options ...
Well this one been in the back of my head to do for a coon's age ...
I hadn't bought it yet, I keep asking myself 'Self, are you that dang lazy that you can't lift your foot to hit the dimmer switch ?'
So far "Self" hadn't got back to me ! .. Do think he's avoiding the question ...
(Think I'll consult the "Magic 8 Ball")
There is a reason that I'm pondering on this ..
Back in the 70's I worked for a Cadillac dealership, installed many of these on cars that didn't come from the factory equipped with one ...
Opps .. !
Wrong critter ...
This gizmo keeps the lights on after you leave the car for a minute or so then shuts them off ..
This is the critter I'm thinking about ..
GM first made these in 1952 on Oldsmobile's
Last year was 1988 Cadillac's
I would want the later year model that had the eye mounted in the grill not on the dash ..
dragstews
Jesse
R-100
406 ci SBC
Don't know why, but I just bought a 454 BBC that came out of a low mile motorhome ...
Don't need a motor for my truck, the built 400 mouse motor that's been in it still runs like day one ..
Going to do a tear down on the new to me motor and build it back warmed up a bit ... Might stick it in the Binder ??
Photos in a short ...
Block casting numbers are 14015445 ..
From what little research I've done so far, it could have 4 bolt mains .. Soon to see when the pan is pulled .. ?
Edit; Nope, Two bolt
dragstews
Jesse
R-100
406 ci SBC
Got all three loaded ...
Sure is a lot brighter than what was ...
Since I'm doing a makeover on the beast I rolled the miles back to zero .. The 2 tenth is from me hand spinning the critter ..
(It was a slow day, did get it up to 12 mph once)
dragstews
Jesse
R-100
406 ci SBC
Nailed down a set of 049 heads ...
A bit of a road trip to get them ...
These are bare heads, no valves, springs, rocker arm studs ..
Got a game plan in mind ..
Going oversize on the valve heads and reducing the stem from Oem 3/8" to 11/32"...
Springs will be matched to the Comp flat tappet cam .. My pick was for a modest grind suited for street usage
Some port & bowl work will happen ..
alex1992
