TH350 Valve Body Modded
quicksilver702
Henderson, NV
Ben
I recently picked up a TH350 donor for my C10 to rebuild. In the process of disassembly, I came across a question. The valve body was modified (the previous owner used it for "desert racing"), bypassing the Direct Accumulator Piston and Intermediate Servo. The shaft for the Direct Accumulator Piston has been removed from the valve body and the piston was tapped and plugged.
My question is this: can I somehow replace that shaft in the valve body, or am I in it for a replacement valve body that retains the shaft?
I want to return to OEM function as this is a daily driver. Pics below for reference.
Tonimus
Phoenix
Tony
C10 Suburban
Should be able to. Was the hole for the shaft also threaded and plugged?
NickTransmissions
Las Vegas
Nick
Check to see if the direct clutch was dual-fed internally. If so, that's likely the reason the 2-3 accumulator circuit was blocked off.
Also, measure the 1-2 and 2-3 feed orifice diameter - chances are they were enlarged sigificantly for use with a high stall converter. Was the 1-2 acc spring shortened? Any check balls left out? If you want a more or less stock-shifting transmission, you'll want to investigate those things if you havent already done so.
quicksilver702
Henderson, NV
Ben
No, there are no threads. I'm guessing it got pressed out?
No evidence of dual feed (all rings were on the stator and the circuit wasn't blocked. There were zero check balls when I pulled it apart.
This is what I have for springs (pic). It seems like some are missing.
I think at this point I'll pick up a used, normal-looking valve body instead of messing with this further. Thanks
southbaymiller
