- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
some cheap ATC fuses can be hard to spot , they can fail in an apparent fine appearance but have no actual connection to the rest of itself or may have a misleading capacityI was double checking had power at the lighter socket, grounded it out by accident blew the fuse.
Only had a 25 amp fuse left(I did that a couple times the other night) thru it in and everything works . Lighter heats up, lights stay off, lights turn on when I turn the switch.
Yeah I don't know maybe the previous fuse was damaged or something or not put in properly.
