JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Discovered this when I pulled up to Advance.
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Should I bother with some kind of stop seal for the radiator or should I look for a new rad? I will be checking levels and under the truck when cool.
ChuckN
Bellinham, WA
Chad
Seems to me that some of that stuff does occasionally work, but I hate the thought of clogging everything up with something- I can only image that if it will stick to a leak, it’ll stick a lot of other places too that are unwanted maybe wouldn’t cool as well after that, but that’s just my thought.
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
@ChuckN you recently replaced your rad didn't you? What did you go with again?
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
After several hours no more drips...but it dripped alright.
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Should I even try this stuff? I think I want to just replace.
I wouldn't add a stop-leak. There's really no magic fix for a radiator with plastic tanks. Imho, just buy one from a local parts store with a lifetime warranty... then remember where you bought it ten years from now, lol.
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
I went with a Cold Case. I used the code for Vice Grip Garage for free shipping- make sure you get the one with the 1.5” lower outlet.
I definitely recall the problems you had with the lower outlet being the wrong size now...
BLAKMAX
