Have any hunches on what went wrong? I still haven't thought of anything else that could have caused that. Just the collapsed lifters theory.
Oh and just to be clear for others that are wondering what happened, those turned rockers are the effect, not the cause. @PeteJr
Oil pressure,adjusted wrong from the get go,or retainers are sticking up too high letting the rocker walk off of the valve stem. I'll need to look at his pic again to see if I can see if the rockers hit the retainers. I'm curious to see what the builder says. Whoever built it should know what spring retainer combo will work,so I doubt that's the issue. Also need to reread his post to see how many miles are on it.
Ajax19
Socal
Ajax
Oil pressure,adjusted wrong from the get go,or retainers are sticking up too high letting the rocker walk off of the valve stem. I'll need to look at his pick again to see if I can see if the rockers hit the retainers. I'm curious to see what the builder says. Whoever built it should know what spring retainer combo will work,so I doubt that's the issue. Also need to reread his post to see how many miles are on it.
Hard to tell in the pictures but that one stud looks taller so maybe it pulled it self out I know that was a common issue on the stock blocks but I figure blueprint wouldnt have that problem where's the pushrod maybe it's to short I have been planning on a blueprint in the long far off future but that makes me rethinking my decision wonder what they have to say about it that sucks hopefully OP gets it figured out
He's got 3 walking off,so I don't think the studs pulling out.I reread his post,it's got over 1000 miles on it,so the rockers weren't out of adjustment to begin with. He says he hasn't had it past 3500 so he didn't float the valves,oil pressure,collapsed lifters,or wrong retainers is all that makes sense to me.
PeteJr
NW MS
GMC Sierra Classic 1500
Yes, it has run for 1,549 miles since I started it. been to a couple short outta town car shows (50-100 miles) Followed their priming, etc instructions, break in oil, etc.
Oil pressure is always about 55 lbs. going down the road.
That one push rod was laying in the head, it's not bent or scarred. Like I said, when it started making the noise I shut it off and pushed it back in the shop.
The rocker nuts don't look like they have backed off. I am OK with collapsed lifter(s) as long as the cam is OK.
I don't know what cams & lifters BP uses. Edelbrock's warehouse is here in my town.
I have heard local guys here talk about how Comp cam lifters have been bad ???
On a tour there a couple months ago, I asked if they did BP's aluminum heads and the guy said yes ???
I have contacted BP. Waiting on a reply.
...AND, The Atlanta Braves just clinched the post season for the 7th straight year!! I'm excited, don't know where to put this, but...GO BRAVOS!
GOOOOOO SPORTSBALL!! SCORE THE BASKET! :rotflmao::rotflmao: Sorry, had to. That and UGA losing to Abalama is all anybody around here is talking about
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Was bummed about the Dawgs losing to the elephant tide but I'm a C Tigers fan so...see you later?
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Hook 'em horns! #1 and Arch Manning might be the real deal! My aunt and uncle are disappointed that Georgia lost too.
Ajax19
Socal
Ajax
Decided to do the coolant drain and fill I only have the diff and t case fluids left then she'll be all caught up on maintenance for a bit next will be the body and suspension bushings then I can finish up the metal work
BRetty
Los Angeles
Franklin
I finally got up to the shop on Sun aftn, with big plans to change oil, replace valve covers, check fit and filler neck for my new fuel tank....
Ended up commiserating with the boss who was there all weekend catching up on bookkeeping and paperwork, mostly CA sales taxes.
Then I spent more than an hour trying to cram my new f***ing DIPSTICK TUBE into the engine block. I bought it from JEGS. Goddamned hole for it is in the back of the block and since the front was up on ramps, I had to like dive headfirst to reach it. Just DID NOT FIT. I ended up grinding almost a 1/32" off the tube walls all around, then found a tiny hammer I could swing between the upper end of the tube and the brake booster assembly.
I did get my oil changed. With the air horn off, I scoped out all the tangle of tubes and coat hanger wires on my Quadrajet. I found this bobby-pin-thing just unattached. What is it?
ETA: Ever notice that Marxists who shout "Workers should own the means of production!!!" Somehow never shout about INSTALLING or MAINTAINING or even CLEANING the Means of Production?
Or how lazy flaccid "activists" chant that "workers deserve their fair share!" but THEY are not spending 12 hours on a weekend catching up with all the government regulations meant to "protect workers"?
Hmmmmm....
Carb'ed Vortec 350
I might be wrong, but I think it goes in the other slot on that pull-off above the custom vacuum plug. The slot with the spring around it.
BRetty
Los Angeles
Franklin
I agree. Somehow, even though I have a degree in Mechanical Engineering, reading manuals or even looking at diagrams about carbs makes my eyes glaze over.
The linkage has a couple tiny studs on the end to keep it on the cam, it looks like I have to un-hook the tiny cotter pin from the other end, pull that end out, so I can rotate the thing 90deg to slip it through that curved slot. Then re-attach the lower end.
Notice you didn't actually say *what it is*, just where stick it in... ;-}
BRetty
Los Angeles
Franklin
You know, the little choke cam there is kind of inspirational. Christians might see the symbol of a Dove, those from the Southwest might see a symbolic Phoenix, rising from the intake manifold:
Perhaps this represents Icarus, his dreams melted by hubris, or Daedelus his father who knew babymama weren't gonna teach him any sense.
And Others might clean up their old Edelbrock 1404 and slap that on....
Bloodhound1981
MA
Rusty
C-10
Here's what I did to my square lately...I attempted to make a spirited 1/4 mile run in a fairly remote area. After stomping the go pedal, the truck suddenly went to idle only. Well, I ripped the Lokar throttle cable out of the ferrule on the throttle body of my First fuel injection intake. Clearly due to my gas pedal not being adjusted properly. I was just barely able to get a couple strands of cable into the ferrule to limp all the way home. I was half considering making a shoe string throttle haha. Good times.
Camar068
10 yrs Air Force
New switch assy from Tractor Supply got it running. (Most of that style are made by the same company, no matter what the packaging says. This one is "Porter Cable" for example.) Mega sent me a new switch and motor under warranty, so now I have spares, but the long term fix will be upgrading the switch entirely.
Hey.... at least it's still September :p but DANG is this taking longer than I thought. I WAS hoping to cut out of work early tomorrow and get color on the Burb, but it doesn't look like that's gonna happen. :( Got the new cowl hood fitted yesterday, and the wife stripped it this morning, so the epoxy is flashing off on it right now. The whole body, with the exception of the barn doors is blocked out/wet sanded and basically ready for paint.
Went to hang the "new" barn doors, since I got a different set due to ours having some bad cancer at the top and bottom. (dang that seal seems to be designed to trap dirt and moisture) Lets just say..... they're on there, but they don't quite fit. lol So here I am, about to search the forum for whatever lore there is to adjusting them. I'm dreading what I suspect, that I need to bend the hinges to get them to sit right.
Other than that, and selling the 1st born to LMC (and probably another vendor or two) so I can source a bunch of parts I'll need to put it all back together nicely...... it's going GREAT. :oops: Wife wants to lose the silver stripe, so it's gonna be ALLLLL Red, or Victory Red rather. I wanted to do it in single stage, because keeping dust off a fresh clear coat is just NOT happening........ but finding a decent single stage locally is proving difficult. The local Wesco guys were pushing BC/CC and HARD. Told me single stage is "old technology, that nobody uses anymore". :rolleyes: So that's something else I gotta figure out tomorrow.
look at summit single stage if you plan to spray.
2manysquares2care
