- Apr 11, 2017
- kansas
- Rick
- c20
The drums are 24 inch diameter. The plot thickens a little, I looked at my square bed and measured it,not sure what bed you are using. You will need 48 inches between the wheel wells and at least 9 foot of length that would have end barrels hanging over 1ft you could gain some length by putting down a piece of plywood 1st, but if you only have 4.5 foot of bed to work with I think you are going to have to remove the tool box.learn to tie a hay hauler hitch so you can lash off a bunch of times,and those tie offs are crazy tight,like compound bow string tight.
