- Apr 11, 2017
- kansas
- Rick
- c20
The 5.7 will go in real easy same transmission. I believe the same mounts,all the brackets and accessories swap. I think all its going to take is the 5.7 a prom for a V8 truck, probably a different fan shroud, if you use exhaust manifolds from a gmt with a small block I bet the exhaust even hooks up. The 4.3 is basically a 350,with the front 2 cylinders removed.I keep thinking about this thing. My son just turned 10, and he likes the body style of these truck. Might be something we can get fixed together, and be a first truck for him. So, has anyone ever pulled a 4.3 and swapped a 5.7 in one of these trucks? I can’t imagine there would be a tone of difference, since the trucks were offered with both. Any input? I’ve also thought about maybe rebuilding the 4.3. If nothing else, I may drag it home and pull the top end off of the motor and see what it looks like.
