Are my gears to high for the setup?
jstnvndn
Winnipeg
Justin
I have a Saginaw 4spd and 35 inch tires. I feel that when I start off in 1st gear that it is lugging and does not "feel" like a 1st gear start...feels more like a 3rd gear start...so I tried to assess my rear end gear ratio and the 1st gear ratio of the manual transmission. Here is what I found:
1. The rear end indicates a 3.08 - I rotated both tires in the back and counted a full revolution of the tires to the driveshaft revolutions. The shaft turns 3 times to 1 revolution of the tires...so I estimate that it is a 3.08 rear end.
2. With the transmission in 1st gear I rotated the engine 1 full turn and counted the turns of the driveshaft, which only turned about a quarter revolution, so I assume it would take another 3 turns of the crank to equal 1 driveshaft rotation...probably indicating that would be a 3.50 gear for 1st.
Given that I have 35 inch tires, with a 3.50 first gear and a 3.08 rear end would that recipe describe my situation? I have to slip the clutch quite a bit to move the truck out in 1st gear.
I think that by changing either the rear diff or changing the transmission ratios would solve the issue and make it more driveable.
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
I had a Sag in the Nova, was great but had 28" tall tire, and a 3:43. weighed 3260. What Ricko said.
I have 4.10 gears and 31" tires in my K25, and it's a great combination unless you like to drive over about 70 MPH (about 3100 RPM) on the highway. You could use 4.56 gears and be at about the same RPM.
Shorty81
Baby Boomer
North West ohio
Darren
I have SM465 4 speed, 3:73, 31" tires and for me it's perfect. 2000 rpm at 55.
goodwrenchca
