Toad455
- Aug 3, 2023
- North Texas
- Kevin
- C10
I'm fitting my doors on to set the hinge position on the cab prior to removing the doors and finishing the final body work. This truck, like most all, has a fairly large gap at the top and at the A pillar, almost half an inch. This truck was like that since new and I've hated it all the way so I want to fix it. I already fixed the curve at the bottom of the door at the rocker panel by welding 3/32 stainless steel welding rod in the center and making it straight, not that anybody but me will notice at the bottom, but I want to fix the large gaps at the top and the A pillar. I'm not going back with the rain gutters either. The gap is good at the rear of door against the cab, and at the fender, and at the rocker. I plan on welding steel rod and body working to fix the gaps so my questions is should I use rod on the door or on the cab? I guess either but has anybody done this to fix the large gaps in this area before? I attached a couple of pics.
