geauxnow
- Mar 5, 2024
- DFW
- Matt
- V1500 Burban
I bought this suburban and the engine was torn down to the block. The parts, brackets and bolts were in a box with no labels. I'm finding that critical wiring is missing also. I'm using factory manuals but they're for 1988 trucks and up. Mine is an 89 V15 burban so I think I need the service manuals for the generation prior.
First photo is fuel pump relay and the manual shows this cable going to the ALDL according to the 1988 wiring diagram. I don't see a connector or have any other possible connections.
Second is of a connector at rear of engine.
third is a female spade near the dizzy
4th is another female spade in the alternator harness.
Thanks,
1989 4x Suburban
Thanks,
1989 4x Suburban
