randomTruckKid
- Feb 26, 2024
- Rockport tx
- Brian
- C10
They're just grade 8 bolts that were the same size/length as what we cut off.When you say bolt, are you using the correct stud, which I believe is serrated or are you using just a Grade 8 off the shelf?
There are washer/ spacers that go on before you shim but I feel like they are about 1/4". Something is definitely wrong if you are having to put 1" of shims in. If the springs are cut, I could see you having to put a lot of shims in though.
Also some shafts are offset so turning 180 might get you closer.
I'm still confused as to why you are putting C20 arms in on a C10?
We are lifting the truck it was previously lowered 3 in. But I was really suppried when I still had to put quite a few shims in.
then the other side.
Also the c20 control arms were advertised as c10 ones. They must just be people modifying c20 arms to fit c10 ball joints.
