Steering box frame reinforcement weld in plates
Rumbledawg
the back 40
K30 crewcab
a cheaper alternative to them expensive plates and braces.
gm also made a factory brace that was usually installed on 1 ton 4 by's.
i have 38's, 39's and 42" tires for my crew. in over 20 yrs have never cracked the frame, even with the big rubber.
i also have a chunk of 1/4" angle bolted to the frame by the front of the spring hangers, which also makes a handy spot for a front receiver. between the 2 pieces, frame flex is pretty much non-existent around the box saving the frame from any cracks.
blew the sector shaft seal on my old box last yr. frame looks pretty minty to me
dhartman
michigan
daniel
c15
Qe just got ours sandblasted and to my suprise there was no cracks on ours. We are going to be putting the bolt on plate for good measure to keep it from cracking in the future.
JBswth
Vallejo, California
James
C25
292 cubic inches
That is pretty rare. I will say that every time someone tells me that they don't have a crack, after stripping the paint and removing the box, I have always found a crack. On my '77 C10, I inspected it very thoroughly and even had a frame shop take a second look before sending to powdercoat and didn't see anything. After blasting, I found a very tiny hairline crack that I had to weld up.
On that truck I have the autofab brace to the rear of the box and the Ridetech triangulation braces up front. C30's have a triangulation brace and I've always wanted to see if I could adapt it to the C10 frame.
Maybe because mine do not have power steering?
J. B.
Khampton96
