Maxwellvis. A 20 year old with a 1949 Chevrolet truck.
78C10BigTen
pennsylvannia
C10 BIG TEN
Because I know you all like to see and hear stuff too....
The engine was still pretty cold and didn't want to idle well in gear.
Not bad sounding from a cheesy little "RV" cam with 9:1 compression in a 307 with Summit Vortec heads on it...
$h1t sounds killer!
Catbox
Peter
C20 Silverado Camper Special
Not much has gone on with the truck.
Well, he put the rest of the exhaust on it as it was overpowering inside the bare cab.
We had to wear earplugs as it would resonate horribly.
He still needs to put a crossover into the exhaust.
But he loves it.
For a simple 307, it rips and pulls hard past 6,000 and will break them loose at the shift points.
Catbox
Peter
Last week Junior found a set of 15x10's for the rear of his truck to go with the 15x8's he has for the front.
He ended up accidentally buying a 5x5 lug pattern for the rear instead of the 5x4.75 he has.
But since he already has spacers on the rear, he simply purchased a new set that has both patterns.
The tires on the wheels are 275/60/15's for the rear and 255/60/15 for the front.
Previous set of wheels under it.
These wheels look way better on the truck with the same tires.
He had also last week stripped and repainted the front fenders of the terrible faux patina from the PO.
Here it is all flexed out in the ditch...
At the BiMart we found a buddy and Max needed to park next to it for the because of it....
He drives the wheels off of the truck.
Currently it leaks transmission fluid and that is bugging him.
So he is saving to put the 4L80 into the truck currently.
78C10BigTen
pennsylvannia
C10 BIG TEN
Cragars for the win!
Catbox
Peter
Last week he installed a set of air shocks so he could actually use it without bouncing the axle tube off the frame while doing it.
He went and picked up his dirt bikes from my brothers house and it went much better going this way with the air shocks...
78C10BigTen
pennsylvannia
C10 BIG TEN
Some old yamadogs? Whats the one on the other side? Looks late 70s....
Catbox
Peter
The one you can see is the Yamaha IT250 he picked up for $350.
It needed the head and jug to be drilled and tapped for larger hardware as the PO stripped them out.
But now it runs like a champ.
He was putting new tires on it over at my brothers while he dog sat for them while they were on vacation.
You can also see his Polaris 500cc quad under the tarp next to my IT 175 and Kawasaki 100 G4TR.
The other bike in his truck is his 1981 XT250 that he picked up a while ago.
It is the one he has the most seat time on so far.
Oooff, that is an old photo from last year.
Here is one I just took a minute ago.
New stainless exhaust and six pack rack from a vendor in Taiwan and fresh tank from India.
It would seem that other parts of the world had this platform much longer than we in the states did.
78C10BigTen
pennsylvannia
C10 BIG TEN
I have a 77 yamadog It175 tucked away in pieces in my moms basement lol
Catbox
Peter
My IT175 started life as an IT125, but has since been upgraded to the 175 size.
I have just been slackin and have not done the maintenance on it to make it a full blown runner.
He just wanted to have a bigger 2 stroke than I do....
78C10BigTen
pennsylvannia
C10 BIG TEN
Mine was aquired in a family barn sale when i was probly 15... i wanted to get it runnin, so i pulled the motor for rebuild and thats as far it ever got.... Mine has the yellow accents on it and taller bars but looks just like yours.
Maybe not exactly but like this. (Stock pic)
Maxwellvis
Portland Oregon
Max
Silverado Camper Special C20, 3100
Summer meats acquired
15x10 Torq Thrusts wrapped in 325/50-15 Nitto NT555's.
These are ford car bolt pattern, so I will need yet another set of adapters...
It has been decided that I need to keep an eye out for a set of 15x8.5 fronts and use these as my winter wheels, as the clear coated aluminum will hold up to the weather better than the modern crap chrome on my Cragars.
Wheel next to truck for a rough visual of how they'll look...
The current 275/60's look small next to these
Going from a 28x11 to a 28x13 should help the truck look like it has meats.
Fat fenders make the 275 look small...
Summer tires:
Rear: 325/50-15 Nitto NT555
Front: 255/60-15 Cooper Cobra
Winter tires:
Rear: 275/60-15 Cooper Cobra
Front: 235/60-15 Cooper Cobra
Maxwellvis
Portland Oregon
Max
Also picked up a repop chrome rear bumper for 50 bucks, really classed the joint up.
Plate is no longer ziptied to the bumper as well, held in by combo license plate bolt/led plate lights (not pictured here).
The plate bolt/light combo on amazon, we shall see if they survive.
astarko
