TRUCK NOT GETTING FUEL AFTER GAS TANK SWAP
COREY TREVOR
NEW ENGLAND
COREY
76 K20 WITH A 94 TBI SMALL BLOCK . JUST SWAPPED THE FUEL TANK FROM THE VAN THAT THE 94 ENGINE TO A PROPER TANK FOR THE TRUCK . OLD TANK HAD PUMP IN THE TANK , FOR THE NEW TANK IM RUNNING AN INLINE ELECTRIC FUEL PUMP . ANYBODY KNOW WHAT I SHOULD CHECK ? THANK YOU
Why would you go from the in-tank to an in-line? You need to make sure you have hardline from the sending unit to the inlet of the pump or it could be collapsing the feed hose. You also need to make sure you have a non-fuel injected sending unit and that it is being properly powered. I’m assuming you don’t have a tank switching valve?
COREY TREVOR
NEW ENGLAND
COREY
ISSUE SOLVED . . . TURNS OUT MY DUMB ASS PUT THE PUMP ON THE RETURN LINE BY MISTAKE LOL
GXPWeasel
Kansas
Greg
1982 | 2015
Sierra C15 | Silverado Z71
5.0 | 5.3
LOL, That'll do it. Thanks for sharing your mistake. A lot of people would have solved this, and not said a thing so they didn't look like a dope.
fast68chevy
I am the original fast68chevy
LINCOLN IL
RANDY
thats exactly what i was gonna to check if you had two 3/8" ports or lines to make sure its not on return. im kinda surprised your 76 has a return line my 75 pickup doesnt have return lines just the 3/8" ain fuel line and the small little vapor line. both saddle tanks this way.. didnt think there was 3/8" return lines on senders until at least 1980... hmm.,.
rt66paul
California
paul
1991 suburban
Did you fix the Caps Lock key?
87ScottW
