not getting gas to carb
horchata81k10
caldwell
Chad
New problem putting carb cleaner down the carb gets her going but only for bit i step on the gas but it just dies, i had replaced the fuel pump not to long ago before replacing the carb, and i was using it as a daily then one day i was running late so i didn't get to go the pump and just parked at home, next morning i tired to turn it on and nothing i filled up the Lt Tank with about 4-6 gallons and the tank switcher works and you can see the levels going down and up but nothing so im quite sure the fuel pump works , would i need a new sending unit or replace the fuel lines under the frame help.
fast 99
Spokane, Washington
Need to diagnose before buying any parts. Check fuel pressure AND volume, fuel filter then move on to other areas if all is well.
horchata81k10
caldwell
Chad
how can i do that if it doesn’t even run it starts up and dies with spray down it, i’ve got a new fuel filter.
codfish
Drive a hybrid. I NEED your gas!!
Newfoundland
gary
Disconnect fuel line from carb. Crank it over or prime/start it with your favourite spray and see if the pump is working.
Quadrajet carb? Could be a plugged inlet filter.
Codfish
fast 99
Spokane, Washington
Remove line or hose at carb and check flow using a piece of hose and a container of some kind. Remember to disable ignition so there isn't any spark. Crank it over there should be a good squirt of fuel probably about a pint in 10 seconds or so. If that's ok then check pressure, will need a gauge for that.
JOD26
