Sticking Brake pedal
ozark strom
Missouri USA
Milepost
Had many square bodies but never this issue. Got an 83 c20 running now and the brake pedal has a hard time returning. If the vacuum line is disconnected and plugged all better. No change in idol either way. Thinking on swapping out the vacuum booster. Any one had a similar experience?
SirRobyn0
Rob
@ozark strom There is only about two things that can cause that issue. Sticky and rusty linkage under the dash, which usually only occurs if the truck has sat a lot or has been very wet inside long term. The other is an internal problem with the brake booster. That's about it.
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
I had my pedal stick when I had my old axle with a leaky wheel cylinder. It wouldn't stay fully bled with the leak, so the pedal would travel farther than it should, then would get stuck every now and then.
Is your pedal proper? Not almost hitting the floor?
ozark strom
Missouri USA
Milepost
First thanks for the help. Going to dig in deep, check all the brake system over carefully. Its no lower than usual or possibly i have forgotten. Seemed as the chevy had a softer pedal than my ram trucks of late. Will post fix when done.
3dbello
