shotrod69
- Feb 27, 2023
- Florida
- lacey
- R20 Suburban
1987 R20 Suburban.
What’s causing my braking issue?
When ever I hit the brakes the truck pulls to the right. The harder I hit them the harder it pulls. To the point of needing to counter steer with some effort to avoid going in the ditch. Had to “panic” stop in the rain a few days ago, only right tire locked up. Usually both lock up.
Did not find any fluid on rotors or pads. Brakes also seemed (could be wrong) unusually tight when trying to turn hub. Calipers and rotor was also too hot to touch, but not excessive enough to indicate overheating. Temp seemed equal on both sides and cooled enough to touch before I finished my cigarette. Fluid level is good. Hoses look to be in good condition. Both brakes work when pedal is pressed. Pulled calipers and pushed pistons in. Pressed brake 10-15 times to seat pads. Left side was noticeably looser then right.
New parts 32k miles ago.
Master cylinder
Calipers
Hoses
1 rusted brake line
Completely new fluid.
Pads have enough meat left to not need changed.
Master cylinder
Calipers
Hoses
1 rusted brake line
