Power steering fluid .. what type ?
JeffK10America
Easley sc
Jeff
Would like input on what type power steering fluid everyone is using new system no leaks . Say 1985 to 1989 GM of course... also does anybody use the new stuff that's clear for the later models . Thanks
It's what gm used to call for,and if they changed it I never got the memo. They used that same basic Saginaw box in everything for decades.
Yep. It's what GM called for, so that's what I used. I won't claim It's better than PS fluid, but it's one less fluid to keep in stock.
I use ATF in all my GM's for power steering fluid.
what kind of ATF? do NOT use dexron VI or mercon V etc
Dex/merc (old generic stuff) is okay but there is a better fluid out there that makes less heat because its better at keeping air out, and its GMs power steering fluid(pricy)
I have been buying gallon and 2.5 gallon jugs from the farm store the last few years. Usually Dexron 3 or Dex/Merc equivalent.
thatll work. you live in the south now right?
Still Ohio unfortunately. My timing for buying a house was terrible... if I would have waited about 6 months then I could have taken a job opportunity that would have moved me full time to south central VA. Oddly enough, in the last year I've probably spent more time at home than I did in the previous 5 years put together, lol.
Washington
Any atf will be fine, afaik, does it seem coincidental that every mfg recommends “their” brand of atf for ps, but pS pumps are virtually the same?
This is not an application where a specific brand or model of fluid won’t work for any valid reason.
That said, if it already has Ps fluid in it, I continue using the same unless I were to flush it. Although topped off ps fluid with atf more than a few times in a pinch with zero ill affects.
JeffK10America
Easley sc
Jeff
Well I like the ATF myself . I use these for the late model fords and this for the later GM.S I know there's a lot of people on this site that's why I like the input.. ups or downs great info on a lot of topics , tech info
Thanks happy easter
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Not moving to South Central VA? Would have been nice to get up.
Pugs Speed Shop
