Anyone have a CVF power steering pump? What pressure hose to use?
PeteJr
NW MS
GMC Sierra Classic 1500
I have the Blueprint 350 engine that came with the CVF power steering pump.
Of course, I have a new "stock" pressure hose that isn't close to mating up with the port on the pump.
Anyone already figured this out as to what hose to use.
CVF gives a parts list and has a kit to build a braided line, but that's not my direction.
Thanks for the help !
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
I ran into this with a friend. I ended up changing the regulator valve to get it swapped over. Just change out the larger hex part with your old pump I think is all I did.
PeteJr
NW MS
Thanks, Greg. I'll check that out !
FYI........
I removed the port fitting on the CVF pump and was able to use the one from my old PS pump.
This let me use the original type pressure hose, O-ring type, on the new pump.
(Just be warned about the spring inside and don't let the guts of either come flying out when disassembling them.......)
sammygunns
