ChuckN
- Nov 8, 2022
- Bellinham, WA
- Chad
- C10
I got to thinking that, really, I only drive within county limits. Occasionally I’ll pick up a C/K magazine, and last year read about “C10 on the Capital” or something like that, in Olympia, about 155 miles south of me.
So, the next thought was, what do I need to feel comfortable to go that far, meaning, what to I have yet to do? It will be August and by far the hottest month. Trying to think of most likely things I’ll encounter.
Besides the obvious (tools, spare stuff like an ignition module), this is what I have.
1. I need a spare tire carrier, none present on the truck. While I’m at it, I’d like to find a stock jack setup (at least) for the front fender location. Basically, I need to be able to change a tire roadside.
2. New rear tires
3. Ground clearance. Shorter headers that don’t scrape. Chevelle or Camaro?
4. Sitting in hot traffic - I’d like a heavy duty seven blade fan and a clutch to go with it. But most of the clutches out there are junk at the stores.
5. Assess the rag joint/steering gearbox.
I’ll edit/add as I go along- what else would I be missing or would you take?
I’m going to be so bold as to tag @Elliot W here because behind the scenes, we’ve had discussions about trusting our trucks for longer distances after getting them in the road. Apologies to him if he’s already crested this issue. Thanks in advance for all your thoughts, and don’t hold back- if I’ve already done what you have said, I’ll mention/add that to the discussion.
I figure that if the show sucks and I don’t go back, at least it would be an adventure.
2. New rear tires
