BlazerBill
- Mar 24, 2023
- Texas
- Billy
- Chevy K5 Blazer
I’ll be installing a new GM crate 350 into my ‘83 Blazer soon. While the engine is on the stand, I’ll need to pull the distributor to prime the oil system. I’ve not done this before although I’ve watched videos of the process. I’m just curious how the engine will operate in the truck if I don’t get the distributor reinstalled in the same position. Will I be able to correct the timing with just turning the cap after the engine is installed and running or will I need to pull the distributor back out and reposition it? Is there a different way to oil prime the engine that doesn’t require pulling the distributor? Thanks!
