How to fix loose gm steering column
A 13/16" socket is needed to break the nut loose off the steering shaft.....
image upload
upload images
I learned from a previous write up to use a white towel to lay parts out in the order removed:
jpg upload
No, no, correction, there is one screw holding that piece, and 3 others that hold the signal switch to the column, sorry.... :suicide:
And of the 3 screws holding the switch to the column, the upper right one is special to that spot, a pan head, and the other two are the same, keep reference...
Green K10
