- Aug 19, 2010
- Kansas City, Mo
- Jacob
- C10 longbed/R1500 Burb/R3500 Dually
You're my hero!!
I have the same problem with my shift lever, it is really floppy like that spring broke or is missing. I have no idea what it looks like in there or how to fix that. My problem is putting it back together, I think the linkage rod for the high beams got tweaked, and now I can't get it set up right, it's acting like it is too short. So I got to tear it apart again, I just got too hot and pissed off. And I got the replace that white ring piece for the horn connection.Super nice job on the pictures and explanation!!
I had to do mine about a year ago. What a pain in the a$$. My return spring on the shift lever had also broken, so that came apart as well.
Quick question for you; since doing mine, my ignition switch no longer "locks" and it can now be rotated/used without the key. What did I screw up?
BTW, love the front bench seat. Been going back and forth about how I DO and DON'T want one. Hate to loose the head and arm rests of the captain's chairs, as well as the big console, but would love the extra seat so our daughter could hang out up front with us. But, the no center shoulder harness thing, combined with the no headrest thing keeps me from making the move.
Look back on page 2 at photo 28 and you'll see the shift lever comes through the housing and has a finger at the end. Between that finger and the inner housing is a short and stiff little spring. Drive the pin out of the outside of the lower column housing where the shift lever pivots. You don't need to drive the pin all the way out, just drive it enough that the lever can come out. Fish the pieces of the old spring out with a magnet. Set in a new spring. Set the shift lever in place to trap the spring, and then pound the pivot pin back down through the shift lever. IIRC, I pounded the pin upward from under the column, and then back downward again into position after replacing the spring.
I need to address my ignition cylinder situation. I hate taking these columns apart...eventhough I purchased the GM steering column tool kit in order to make it easier. They're just a bitch, no 2 ways around it.
A local dealer had the springs. Probably a common failure item.
Yes, that's the pin in your photo above, but look on page 2 and message 28 for the photo showing how it looks on the inside of the column.
Mine had been loose since day 1, and then one day it was just completely flopping around......we're still talking about column shift levers right?.......so when I had the column torn down, I found the spring in pieces.
...and looks like I got to tear this sumbitch apart again...
Next is this do-hickey, it slides out and sends current to the horn thingy, sorry for the terminology fail, just be careful when pulling it out and replacing it...
free picture hosting
adult upload image
Watch out for this little bastard here. All the parts can pop right out of it and it can be a bitch to put back together again. I also think it's just the contact for the key reminder chime.
