Raider L
- Sep 1, 2020
- Shreveport, LA
- William
- C10
I took great care putting my steering column back together, ( see my lengthy build thread with all kinds of pictures). Well, the other day I was fooling around with the horn button cap and it popped off. Dang! "Now I have to unhook the battery and put the stupid thing back on." Oh but wait! I need to also take the locking plate off, the thing that the steering wheel locking pin goes into when you turn the ignition off, and as you are turning the key there is the raised marking on the upper column housing that says, "lock" on it. That plate is some kind of hardened metal with holes and slots and openings and all kinds of stuff cut into it. To get it off you need a tool that compresses the spring behind it and a wire lock ring laying in a groove in the steering shaft must be removed. Once that's done the locking plate comes off.
Any way I got all this off and went in the shop and did the best I could and straightened the locking plate out. Back at the truck I remembered that I had a problem with the signals not cancelling so I took the cancelling cam and put it on the shaft to take a look at what the problem could be.
But before I put the locking plate back on I took the opportunity to work with the cancelling cam to see just exactly what it was it did to cancel the turn signal. I put the cancelling cam on and pulled the turn signal lever down, then up, and turned the cam back and forth trying to get it to cancel the turn signal off and I never could get it to turn the turn signal lever off. Either I'm just to dense to get it but I could not ever get it to work.
So, I got the factory book out and any photos of it and the function I copied off the internet because the factory book has nothing on it. Well, I found nothing on how this little devil is supposed to work. I even put the cancelling cam on the shaft and just kinda put the locking ring up on there to see if maybe by some mistake I had it on there all wrong. Nope! It can only go on one way...that is unless I have the steering shaft turned wrong down where it attaches to the intermediate shaft, up at the firewall where the steering shaft comes out and you bolt it to the top of the intermediate shaft coupling. But if you remember there is a ground down place where the bolt slides through the coupling. It in turn lines up with a flat spot inside the coupling and it has to go that way or you can't get the bolt in. It has to go that way.
So, I'm at a loss. I don't know what the problem is, and anyone who thinks they have a solution has to be well versed with the whole area at the steering shaft there where the cancelling cam and all that fits. Maybe if someone has a tilt steering column out of the truck and can duplicate what I'mm talking about and figure out what is going on. Or maybe if someone has a spare truck, or their running truck's steering column apart and can take a look themselves to figure out what's going on and why mine won't work!
I'd appreciate it very much!
The special tool for removing and installing the locking plate. Okay this was the last pic I loaded and now the post with the wire coming out of it IS at 2 o'clock position, and is the way it is on the truck now.
Well, dang, all the pics I took are all blurred, so here's what I'm talking about. Most all of you know this.Any way I got all this off and went in the shop and did the best I could and straightened the locking plate out. Back at the truck I remembered that I had a problem with the signals not cancelling so I took the cancelling cam and put it on the shaft to take a look at what the problem could be.
Here's a pic I took when I was putting the column back together on the bench so I could look at all the different ways this cancelling cam could go in and found that in order for the locking plate to line up correctly the pointed center hole in the plate needed to line up with a flat spot on the steering shaft, like here.
I don't know about this pic because this is not how the locking plate is turned in the truck, now. as you can see the post the wire for the horn comes out of is at about the 9 o'clock position. I remember having the locking plate on wrong where it wasn't lined up with that flat spot on this end of the steering shaft and had to take it off a couple more times to get it lined up right. The way that post with the wire coming out of it is now in the truck is at about the 2 o'clock position. But before I put the locking plate back on I took the opportunity to work with the cancelling cam to see just exactly what it was it did to cancel the turn signal. I put the cancelling cam on and pulled the turn signal lever down, then up, and turned the cam back and forth trying to get it to cancel the turn signal off and I never could get it to turn the turn signal lever off. Either I'm just to dense to get it but I could not ever get it to work.
The small end here is where the grooves are, and right there between the ears where the bolt goes through is the flat spot. That has to line up or the bolt won't go in. I am absolutely certain mine is correct, otherwise the bolt wouldn't have gone in.So, I'm at a loss. I don't know what the problem is, and anyone who thinks they have a solution has to be well versed with the whole area at the steering shaft there where the cancelling cam and all that fits. Maybe if someone has a tilt steering column out of the truck and can duplicate what I'mm talking about and figure out what is going on. Or maybe if someone has a spare truck, or their running truck's steering column apart and can take a look themselves to figure out what's going on and why mine won't work!
