cab/Body mounts
mummertj
manassas va
Joseph
k 20
I have a 79 k 20 regular cab truck
That has an 81 cab on it I want to replace the body mounts but the split is between 80 and 81 does anyone have any history on this which kit should I use what’s the difference between the two kits do I need to combine both kits
MarineOne
Western New York
To my understanding the only difference is thickness of rad support bushings
Termite_Delight
Lanark Ontario Canada
K2500 K2500
350 L33
Use the body mounts for the frame, 2wd and 4wd frames use different mounts. The mounting surface of the cabs are all the same.
3dbello
