81 350 SBC is farked, about to replace with 350 SBC bought locally
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
I'd say keep the snorkel. The heat stove won't do anything unless the tube runs up to the air cleaner housing.
BRetty
Los Angeles
Franklin
My mechanic has been backed up, but I gave him a deposit so he will hopefully have time/room next week. Meantime, I took a closer look at the engine and have a couple questions:
What is this device? It's mounted right in front of the throttle linkage, by the A/C compressor, and looks like an electrical sender:
I noticed that a small fin got broken off the quadrajet carb, by the hoisting chain. Is this a major problem?
Thanks, any info appreciated.
BRetty
legopnuematic
Licensed Junk Dealer
MO
Spencer
That’s an idle solenoid, on an A/C equipped truck that should get +12v when the compressor is cycled, energizing the solenoid, it will then extend and push on the throttle arm raising the idle/keeping it from dropping with the extra load on the engine.
As long as the broken fin didn‘t create or reveal any holes into the bowl below I think it would be ok to run as is.
BRetty
Los Angeles
Franklin
Thanks Lego! I' probably going to delete the A/C, but def. Will keep that solenoid with the compressor. (And The bracket for it.)
They still going to hit you for smog down there?
1975 Model year and older does not need a smog inspection in California. They can still get hit with citations for things if you are pulled over by a cop and that can lead to other issues, but 1973 and older doesn't even have any emissions requirements under the clean air act... so they would have a hard time actually prosecuting anything like that.
https://www.dmv.ca.gov/portal/vehicle-registration/smog-inspections/
BRetty
Los Angeles
Franklin
Update (or not)
I am still waiting for my 350 transplant. The bottom line is that my mechanic in Hollywood just has no space at his shop, so he is very hesitant about having a large non -running vehicle there. Theoretically the engine swap should take a day or two, but if anything goes wrong he would be jammed up by my truck sitting there.
Sometimes I hate you all, with your 16 acre lots and multiple outbuildings and oil sumps. There is no goddamned place in Los Angeles County I could do this engine swap myself, unless I wanted to be one of the RV homeless on the side of the road. But those freaks guard their illegal parking like ... well, like crazy bums do.
Im really boned
Snoots
Roger
Jimmy Sierra
GTFO of there!
Washington
Well I lost the best paying job I ever had for not agreeing to move to LA. I regret the first part and nothing else about the decision.
I also understand there’s not any other places in the country to do what you do for a living full time likely. Except maybe Santa Fe, NM.
That said, IMO there’s really only 2 good options for someone who needs a vehicle daily to make a living and survive.
1, if you’re going the old bomber cheap vehicle/antique/ whatever route, you need at least 2 of those vehicles so you have a backup.
That’s how I got through the first several years from 16-20y/o.
Or 2, you need to dump the old bomber (or keep it) and get a reliable car. End of story.
Since physical space is at a minimum and your job is at stake according to you, I’d save the money spent on a old oil soaked engine, sell the old truck (pre 75s should go quick and decent money as a roller in Commirfuckya) and go get a decent truck.
You can still roll in a soon to be classic Chevy.
But if you don’t have the time, space and means to constantly fix an old car then you need one that is reliable and runs.
JMO.
Sounds blunt but these trucks are nothing special or rare yet and won’t be for a long time imo. Can get another one when you have the means.
RustyPile
Elkhart, TX
Nick
1983 GMC
350 SBC
Update (or not)
Im really boned
I'm at odds with the statements in your second paragraph.. I'm one of those that owns 16 acres (In my case it's only 10 acres of totally rural property) with outbuildings. It's not my fault you chose to live in "goddamned Los Angeles County".. You made that choice yourself..
I'm a former shop owner so I've been on your mechanic's side of the fence.. No way would I take in a job like. Especially a vehicle that old. Too many unknowns to contend with.. He has only the customer's word that the engine is a good one. He gets the engine installed and it won't run.. Has some expensive issues.. The only warranty he can offer is the dang engine won't fall out. No way is he backed up over 2 months. Not this time of the year. He has a reputation to uphold and has given the project further thought.. Not worth the headaches so he "excuses the customer" out the door.
BRetty
Los Angeles
Franklin
Well I finaly got the engine swapped. Bribing the shop with pizza was the key.
Now I have a question I'll post here rather than a sep. thread. I have the old engine and want to tear it down...
-- What is the best way to mount an SBC on an engine stand?
--Can I bolt to the rear bellhousing threaded bosses? Or should I take off the front and bolt on the block from that direction?
Thanks,
BR
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Thanks,
BR
Grade 8 bolts and washers, and bolt it to bell housing portion, as centered/balanced as you can so rotating the engine is easier. I haven't paid attention to the last part before, and when it came to turning the engine over it was a pain to rotate. Can still be done, but if it's more centered weight-wise where it rotates on the stand, it'll be better.
BRetty
Los Angeles
Franklin
Thanks for the info, I thought bellhousing but was not sure.
calebrwalk5
