- Aug 3, 2010
- Usually not in Ohio
- Andy
- '77, '78, '79, '84, '88
- K5 thru K30
honest question - why would you recommend mechanical rather than electrical? I would have thought having a wire running the length to under the dash would be easier than a pipe, provide a faster signal, and not have the potential issue of a messy leak in the cab. I am assuming the electrical plumbs into a "mechanical" pressure sender on the engine block - what am I missing??
@Ricko1966 is spot-on. I only recommended a mechanical gauge because even the cheapest ones tend to be accurate in my experience. But a cheapo electric gauge setup can be off by 10 psi or so. Buying quality stuff (like Autometer) will be accurate either way, as long as the electric sender matches the gauge.
