SirRobyn0
- Dec 6, 2019
- In the woods in Western Washington
- Rob
- C20
So a little over a year ago I had a thread going regarding this very topic. A few opinions were thrown around a long with what oil folks have used and had good luck with. At the shop at the time we were using a ZDDP additive when we had a classic car owner ask for high zinc oil, since then I've researched and learned a heck of a lot about ZDDP and what it does and doesn't do. To that end we still only use high zinc oil by request but have switched to using Valvoline VR1. So I'm going to try to summarize what I've learned in hopes that it will help anyone that isn't sure if they should be running high zinc oil or regular oil.
For this article I'm sticking to just what I read or watched from interviews or articles written by oil scientists, regarding the need or possible need for high zinc oil in a flat tappet cam.
For the sake of this discussion it will be focused on conventional oil not synthetics, but the same principles apply to both.
ZDDP also commonly called zinc is Zinc dialkyldithiophosphate a complex chemical compound that in engine oil coats the inside of the engine, heat helps to essentially bake it on. Since camshafts are not lubricated well, and flat tappets cause the camshaft to contact and slide across the bottom of the lifter, lubrication is especially important. But just oil alone is not good enough, especially when under high stress, and at start up so zinc on the cam and lifters keeps the lifters from dishing and camshaft lobes from flattening out.
Facts: Zinc was introduced into engine oil in the 40's first at very low concentrations it was originally used to reduce corrosion. When engineers realized the cam wear benefits the concentrations quickly went up to about 500PPM, until 60's where it started going up again. Topping out in the 70's at an average of 1,400PPM. The problem with ZDDP is that when it burns off in the combustion process even in small quantities it coats the exhaust and reduces catalytic converter efficiency. So starting in the early 80's zinc levels have been on the decline. And in part do to the lower zinc levels oil now has more detergents in it. Allowing longer gaps between changes and cleaner engines.
The current API rating limits ZDDP levels to no more than 800PPM, and most all even discount oils are very close to that 800 limit.
Race oil or off road oil does not have to conform to API ratings so those oils can have more.
Diesel oil can have more ZDDP in it, but some formulations are low zinc. The higher zinc content diesel oils that I'm aware of are as follows:
Chevron Delo 15W40 1,100ppm
Mobile Delovac 15W40 1,050ppm
Shell Rotella 15W40 1,150ppm (seems to be gold standard of choice if using a diesel oil for flat tappets)
O'reilly's heavy duty oil 15W40 1,130PPM
But wait there is more. As a general rule the ZDDP levels in diesel oil have been going down as well. The down fall to Diesel oil is that it is very high detergent. Those high detergents will have the tendency to "wash away" a lot of that zinc before it has a chance to do it's job. That is one of the reasons that higher detergent oils didn't come along sooner for gas engines. Also the reason that oils such as VR1 and other high zinc oils have "reduced detergents and are not suitable for extended oil change intervals. We recommend no more than 3,000 miles between changes on VR1". That quote came from an Valvoline oil scientist. The scientist that would go on to say that if your running a stock engine with a well broken in camshaft that todays modern oil is likely to be just fine. If it's a high performance engine with heavier valve springs or high lift cam then VR1 would be the better choice. But again keep in mind that VR1 does not have as much detergents as modern oils.
A few high zinc oils and their levels:
Valvoline VR1 10W30 & 20W50 1,400PPM
Joe Gibbs Driven HR 1,400PPM
It is also possible to have to much zinc, to high of levels can cause damage. Generally speaking in a street engine it is unlikely you need anything over 1,400PPM. One of the reasons that zinc additives are not recommended, also it seems to be largely unknown how well those additives do or don't mix with whatever flavor of oil your using. At the very least if your going to use a zinc additive have a UOA done on the oil with the additive in it to be sure your not getting to high or not high enough.
Summary: If your running a well broken in engine regular modern oil is probably just fine, unless you push the engine a lot, example: A truck that tows or hauls heavy loads. If you do a lot of that or want a little added protection, then you might want to choose a diesel oil or a high zinc racing oil. If you choose to run a diesel oil, (make sure you pick one with higher zinc), your probably going to get some benefit from it, but the high detergents may work against the higher zinc levels to some degree. If your running a high lift cam and / or heavy valve springs it might be a good idea to choose a high zinc racing oil.
So there, not trying to tell anyone what to do, and if you have been using an oil and it's been working for you I'm not suggesting that you change it, but if your not sure what is best maybe this will help you out.
