WTF is going on......
elstm3
montana
lynn
V30 crew cab dually
6.2 twin turbo diesel
Dose the pink/fusha wire have an inline fuse in it that may have blown?
Just clarifying here the truck does not crank or the truck cranks and does not start? Should be the large cable from the battery, and two feed wires on the big post on the starter and the crank signal wire on the little post. The manual I have for your truck shows that as a purple wire. That purple wire runs up the harness through a connector into the cab to the neutral safety switch. (If it is a manual trans it goes to the clutch safety switch.) From there it goes to the ignition switch.
uprdn84
Gulfport, MS
Steven
Could a busted tilt column cause the problem ?
All the wiring is below the column. The purple wire is not fuseable linked.
Go to the neutral safety and by pass it and check it.
uprdn84
Gulfport, MS
Steven
I know I'm sounding dumb here but exactly where is it. what's it look like and how do i by pass it?
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
Have you tried jumping a wire directly from the battery to the starter to see if it turns over?
uprdn84
Gulfport, MS
Steven
Yes it only arcs. i need to know how to bypass the neutral switch .
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
On the top of the steering column down by the firewall is a half moon switch with two connectors. One connector is for the reverse lights (has one green wire and one black if I recall) and the other is the neutral start connector and this is the one you jump the connector and see if it starts then.
uprdn84
Gulfport, MS
Steven
One connector. blue and green. jumped the plug.... nothing .
uprdn84
Gulfport, MS
Steven
Can someone please call me? 228-223-8209
uprdn84
Gulfport, MS
Steven
No other connectors. just the one.
mlcd
