WTB 454 Serpentine Accessory Brackets
mrdap
USA
C/K_Lover
C20/K30/V15/V2500
Hello to All,
I am retrofitting my '82 C20 454 with a serpentine accessory drive system.
I've already collected most of the parts but I'm still looking for a few.
These would be parts from a
89-91 RV 100, 200 (06) L19/7.4N,
Or
92-93 CK L19/7.4N
Probably 88-89 CK also
Basically 89 to 91 squarebody pickups or suburbans with 454
And some of the later models up to 93 or 94 with the 454.
Alternator bracket, it's a two-piece part, left side of engine top of intake manifold behind the alternator.
See attached photos.
Thanks in advance!
MarineOne
Western New York
I've went this route and if your looking for stellar function and quality over original setup cvfracing.com has fantastic options
mrdap
USA
C/K_Lover
C20/K30/V15/V2500
I've went this route and if your looking for stellar function and quality over original aperanve cvfracing.com has fantastic options
Thank you for that recommendation!
mrdap
USA
C/K_Lover
C20/K30/V15/V2500
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
I just worked today tearing apart a 454, think it was a 94 or 95. Didn't have that style bracket. Did take what bracket it had though, if that's help
mrdap
USA
C/K_Lover
C20/K30/V15/V2500
Thanks for checking.
These would have been on top of the intake manifold on the front driver side of the engine, supporting the alternator.
Well I'm always interested in parts.
Maybe shoot me a picture?
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
The alternator on this 454 was on the passnger side. AC pump was on drivers.
Ill take a pic tomorrow. Think the alternator is still on it.
mrdap
USA
C/K_Lover
C20/K30/V15/V2500
Sounds like a different setup than what I'm looking at using.
But I'd still be very interested in seeing it.
Thank you.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Sure, will do.
This was out of an RV. Have a serp style belt going from water pump to alternator, then v belts on the AC, power Steering, smog, and hydraulic pump.
618Syndicate
Southern Illinois
C30
Duramax
I have this one, but not the others.
mrdap
USA
C/K_Lover
C20/K30/V15/V2500
Thank you so much for checking!!!
Yes that is a big block engine lift bracket but unfortunately it's not exactly the one I'm looking for.
The one I'm looking for is a heavy cast iron piece with two threaded bolt holes in the top.
Thanks again for looking for me!!!
Turbo4whl
Downingtown, PA
Wayne
When you change from "V" belts to a serpentine belt, you need to swap the water pump too. Not just the pulley, if you are spinning it backwards.
Obullard74
